Page <1 4567> |
![]() Posted: 21 Aug 2018 at 1:04pm |
Probably just a matter of semantics, but I like the way it is described in my PD4655 manual:
lgblau ![]() Senior Member ![]() Joined: 09 Feb 2018 Location: Arizona Online Status: Offline Posts: 140 |
Best explanation so far.
Leonard🌵
2017/179 2017 Ram 1500 |
DavMar ![]() Senior Member ![]() ![]() Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
+1 to both GlueGuy and fwunder who both are just describing the same functions differently. Hooked up the "charge wizard" pendent to my Progressive Dynamics circuit board today. I like now having the options of stepping through different charging modes and being able to quickly diagnose a problem with the converter.
I disagree. Right out of the WFCO manual.
"The WFCO Normal (Absorption) Mode alone is a powerhouse, capable of charging a fully-discharged battery in under three hours at 13.6 volts. When the RV is being used, the battery is kept readily charged in Normal Mode." After significant time and no change in draw mine drops to 13.1 volts. That is float mode. I have and continue to monitor and it works fine. Where are you getting your info? |
fwounder,
Your explanation is no different than the charge voltages for a WFCO. 3 phase. |
Mike, Just a different way of saying it that makes more sense to me. BTW, I don't think the WFCO has an equalization mode, does it?
Fred. here is what WFCO says, sorry for length:
WFCO’s automatic three-stage converter handles every charging need for the RV while extending the battery’s life. In fact, well-maintained batteries should never need more than WFCO’s two-stage (Normal and Trickle) charging modes. Our Fast Charge third stage (Bulk) is for the rare times a battery needs extra-power charging. The WFCO Normal (Absorption) Mode alone is a powerhouse, capable of charging a fully-discharged battery in under three hours at 13.6 volts. When the RV is being used, the battery is kept readily charged in Normal Mode. However, if the converter detects no significant variation in current draw for approximately 44 continuous hours, our Trickle (Float) Mode automatically kicks in and brings the battery back to full charge. Maintaining full charging in this manner helps prevent stratification of the battery’s fluids, which can reduce the battery’s charge and longevity. For those cases when the battery charge drops significantly due to prolonged disuse, poor maintenance, or by significantly heavy system overloads, our 14.4 volt Fast Charge (Bulk) Mode kicks in. Our Fast Charge provides a maximum four-hour charge in order to prevent battery damage. This maximum time feature has been implemented to protect and extend the life of the battery. The problem with overcharging a battery is that it tends to convert the water molecules into oxygen and hydrogen gasses, which can deplete the water and leave a strong acid solution, possibly damaging the battery. WFCO’s smart engineering makes Normal and Trickle the only charging modes the RV battery should ever require when it’s properly maintained. |
I'll take your word it says the same thing, Mike.
![]() fred
Thanks Fred:)
Preston ![]() Newbie ![]() Joined: 29 Mar 2018 Location: MA Online Status: Offline Posts: 4 |
Have converter problem. Is warranty with manufacture not FR? Also what is the mpg when F-150 towing pod?
Thanks
Preston
2015 F-150 XLT |
Page <1 4567> |
