Page <12 |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6434 |
![]() Posted: 23 Nov 2018 at 9:04pm |
The 15A breaker in my house would trip when I tried to run the AC. I had the choice of running a 20A or a 30A RV circuit. I chose the 30A circuit. I don't go crazy with it, but I have not had any difficulties running everything I want to run. I just don't try to do so all at once.
I'll double-check, I just about know the circuit I use is 15A. But I didn't install it for the Pod. I just run an heavy duty extension cord from an outdoor outlet I already had. If I were going to run a circuit from scratch I'd certainly go with 30A. TT
FJ Cruiser |
crankster78 ![]() Senior Member ![]() Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Greetings: You also need a 30 amp 120 volt single pole breaker in your main panel. Use 10 gage with ground. The boxes are available at most Home improvement stores. If you are not sure on what you are doing, hire an electrician. I have one at home and the Lake cottage. Crankster78 R-179
Crankster 78 R-179 2015
Hardest part is getting the right fit CB (style and type), once wiring is in, plug and play.
I had a time trying to figure out the correct type of breaker. I finally saw a label on one of the other breakers in the box that let me know the brand and type to install. One can't simply interchange brands. Square D will not interchange with Siemens for example.
+1, I pulled a breaker and took it with me to store:)
Shane ![]() podders Helping podders - pHp ![]() ![]() Joined: 09 Sep 2018 Location: Northern IL. Online Status: Offline Posts: 98 |
I am installing one at the house to test everything before I hit the road, I get upset when I get to a campground and something is not working properly, that's the reason I am installing one at the house. I am using a 30 plug with 10g wire. The unit comes in a weather proof box that I am installing on the outside of my garage.
Page <12 |
