Page 12> |
CoffeeGuyR190 ![]() Newbie ![]() Joined: 02 Nov 2018 Online Status: Offline Posts: 11 |
![]() Posted: 15 Nov 2018 at 9:30am |
Has anyone lifted the frame off the axle and put larger diameter tires to get better ground clearance? I have a new 190 and my driveway is such that the grade doesn't allow me to back the trailer up without scraping. Even if I remove the spare tire rack and the stabilizer jacks it would scrape by a few inches. I think a 4" total lift would work, plus give me better clearance overall.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
All the Hood River Edition R-pods have a 2 or 3 inch lift. The later models do this by "clocking" the torsion axles. Earlier versionsput a 2x2 steel block between the axle and the frame.
lostagain ![]() Senior Member ![]() ![]() Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2588 |
I wonder how hard it would be to "clock" the existing axle. Has anyone done it?
texman ![]() Senior Member ![]() ![]() Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
I added the lift kit. Adds 3.5” I think.
QUOTE=texman]I added the lift kit. Adds 3.5” I think.[/QUOTE]
What kit did you use? and what year is your Pod?
Coffee guy
It is a 2015 182g. Got the kit from my dealer. $140 I think. I think you can order direct from forest river as well.
marwayne ![]() Senior Member ![]() ![]() Joined: 25 Oct 2011 Location: Edmonton AB Can Online Status: Offline Posts: 1002 |
I think it would be next to impossible to "clock" the existing axle. The brackets are welded on. Cutting them off and re-welding to change the angle and then re-welding would likely do too much damage to the rubber components. The only options are to add a lift kit and if that is not enough, buy a new axle with a different angle.
Thanks StephenH. I already put risers on a couple years ago. They made a big difference getting into the driveway.
But ever thinking of new adventures, I thought it would be exciting to make a run down the Baja California peninsula following the race route, but with our pod and my truck. I don't think I'd enter the race though. Seriously, it would be nice to have that much more clearance for Forest Service roads. I always worry about banging the axle on a rock or something.
Page 12> |
