4Papa
Topic: Anode Socket & Screw Sizes Posted: 04 Nov 2018 at 6:47am |
In the (first time for me) process of winterizing this weekend and decided to pull the anode rod. Anyone know offhand the socket size of the nut head? I assume it’s SAE.
Also, for you intrepid modders who’ve put screws in the interior walls, what’s the maximum size screw (depth or length) I can use that will give me the most bite yet keep me safely away from puncturing the outer skin? Thanks in advance.
2017 180
2010 GMC 1500 Hybrid
Posted: 04 Nov 2018 at 7:00am |
1-1/16 inch. 27mm should work also if you're a metric guy.
The wall cavity is 1 inch but its foam filled and the wall material is thin so anything where the shank penetrates more than 1/4 inch is probably going to have the same pullout strength. For more strength you can try to hit the aluminum box tubing in the walls, depending on what you're trying to do.
Here's a great video of what's going on in the walls.
https://www.youtube.com/watch?v=vMXneKc_fDo
4Papa
Posted: 04 Nov 2018 at 7:36am |
Thanks, Offgrid, for the prompt reply and exact answer! Now to rummage in my toolbox...
2017 180
john in idaho
Posted: 04 Nov 2018 at 9:35am |
Be sure you relieve the pressure in the tank before you pull the anode rod. Even if it has been some time since you had the pump on. I know from experience that the pressure can blow both the rod and the 1/2" socket set a good 10 feet.
marwayne
Posted: 04 Nov 2018 at 11:09am |
Posted: 04 Nov 2018 at 12:07pm |
Are those dimensions the total thickness or just the foam?
marwayne
Posted: 04 Nov 2018 at 1:40pm |
Total.
Posted: 04 Nov 2018 at 2:51pm |
Gracias!
Posted: 04 Nov 2018 at 3:16pm |
John,
I also relieve pressure to tank, but also uncap low point drains.
4Papa
Posted: 05 Nov 2018 at 4:51am |
Thanks for the tips. Winterization done. Once r-pod gets put away in tractor hooch Season 2 is officially over.
2017 180
