  New Posts New Posts RSS Feed: Heater vent?
Topic ClosedHeater vent?
Mbearden View Drop Down
Direct Link To This Post Topic: Heater vent?
    Posted: 30 Oct 2018 at 6:39am
I seem to remember that the wall vent outside the bathroom door was supposed to be a heater vent. We have a 2019 189.
Mike Bearden
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 30 Oct 2018 at 7:29am
Nope.
Direct Link To This Post Posted: 30 Oct 2018 at 7:31am
Should be the same configuration as in my 179. If you're referring to the little vent under the door, that's not a heater vent. It just vents the underside of the bathroom and also act as an air source for cooling the battery charger.
Direct Link To This Post Posted: 30 Oct 2018 at 7:44am
It's just a cover for the access hole to the shower plumbing.
harrypodder View Drop Down
Direct Link To This Post Posted: 30 Oct 2018 at 8:01am
It is a very small opening for plumbing work you may be able to work on the shower trap. Thinking FR located it there for all of the above access to the trap, ventilation for under the shower and air intake for the power converter (charger).
Direct Link To This Post Posted: 30 Oct 2018 at 8:08am
Great answers.
Has anyone thought about some making a diverter to direct the air out of the under bed area?
Mike Bearden
Direct Link To This Post Posted: 30 Oct 2018 at 8:36am
Use the advanced search, type in Air Diverter, you'll find the latest post on a diverter made from a lasagna pan plus discussions of benefit.
Direct Link To This Post Posted: 30 Oct 2018 at 9:33am
If you do this, make sure you leave the square area and space around it for cold air return, otherwise, you will be just recirculating much of the hot air back through the furnace. If you take the cover off, you will see better what I mean. The output is an L shaped area. The square is intake and sail switch and the perimeter of the cover is additional cold air return. A lasagna pan is not the ideal diverter as it would not allow for proper cold air return. There was one built that was a proper one that left the proper areas open for circulation and just fit around the output area to divert the airflow outward. Look for that design. It would be much harder to build, but would be safer and more effective.
Instead of that, I use an O2 Cool 10" fan and a 12V adapter cord. I place that in the opening next to the wardrobe to pull the hot air out and circulate it to the larger area of our 179. The side closer to the dinette and furnace is open for cold air return. This has worked well and the constant fan sound helps cover the furnace's cycling on and off.
Direct Link To This Post Posted: 01 Nov 2018 at 7:28am
Looked for the Air Diverter information and came up empty
Mike Bearden
Direct Link To This Post Posted: 01 Nov 2018 at 7:58am
Here you go, its a little way down in the thread.
http://www.rpod-owners.com/forum_posts.asp?TID=12284&KW=furnace+air&PID=116123&title=furnace-filter#116123
