  New Posts New Posts RSS Feed: Battery
Topic ClosedBattery
Rod View Drop Down
Direct Link To This Post Topic: Battery
    Posted: 24 Oct 2018 at 4:39pm
Do I need to pull battery and store in garage during winter
TheBum View Drop Down
Direct Link To This Post Posted: 24 Oct 2018 at 4:51pm
If you're not going to leave it on a trickle charger, yes. It would be a good idea to put it on a trickle charger in the garage anyway.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 24 Oct 2018 at 5:27pm
+1.
OIr, if you have ac power to the pod over the winter the pod charger can do the job for you.
Direct Link To This Post Posted: 24 Oct 2018 at 5:31pm
At a minimum, I would not store Pod with battery connected and no charge capability. You have several options, trickle charge battery, disconnect battery, or remove battery and trickle charge elsewhere. Not charging battery will negatively effect the battery life. So unless you want to buy battery yearly it is best to care for it.
Direct Link To This Post Posted: 24 Oct 2018 at 5:41pm
One additional option if you have no ac power but its sunny where you store your pod is to disconnect the battery from the pod and get a small solar module to put on the pod roof to trickle charge the battery. A small 5 or 10 watt module if OK without a charge controller if you have flooded type batteries.
+1, we bring ours in for the winter and put it on a trickle charger. Had one in my snow machine freeze and crack once, makes a heck of a mess!
Direct Link To This Post Posted: 24 Oct 2018 at 9:19pm
Our batteries (12 v deep cycle group 24) are nearly 8 years old and going strong.  We pull them out and place on a concrete floor in an unheated garage.  First thing is to check water level in cells and fill accordingly if necessary.  Next is a 2 amp trickle charge that takes about 24 hours to bring to full charge.  This was done just last week.  Now they will sit with nothing done to them until next April when I will repeat the above process.  Has worked well for us.
Direct Link To This Post Posted: 25 Oct 2018 at 4:07am
Jato, its gotta be c-c-c-cold in your garageCry
jato and Leo B are both right.
Contrary to urban legend, cold storage is good for lead acid batteries because it slows down chemical reactions so it reduces battery self discharge and corrosion rates. Cold storage is bad if the battery is or becomes discharged because that consumes the sulfuric acid leaving water which is of course subject to freezing.   jato's initial trickle charge takes care of that. A fully charged battery won't freeze until -70F or so.
But if jato moved to say Phoenix or Miami and tried the same approach he would probably have dead batteries from self discharge by spring. So bottom line is, if you don't live in a cold place and/or are unsure, leave the charger on or run it every few weeks and check the water level occasionally. Leaving it on won't hurt anything.
The main reason ppl think cold is bad for batteries is because their internal resistance goes up when its cold (same deal with slower chemical reactions), so they can't put out as much current as they do when they're warm.  A tired battery that was holding its own in summer will tend to fail at the first cold weather.  Cold is bad for battery performance, but good for battery longevity.
crw8sr View Drop Down
Direct Link To This Post Posted: 25 Oct 2018 at 2:21pm
Ours is in the garage for the winter on a trickle charger.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
