Thermal Pictures |
Post Reply | Page <12 |
Topic: Thermal Pictures Posted: 11 Oct 2018 at 5:14pm |
Funny, I'm with you.
Posted: 14 Oct 2018 at 6:38am |
One thing I've noticed from using thermal imaging cameras over the years is that they tend to exaggerate the temp differences. I don't know what device was used for these photos but most of them now autorange the false colors based the highest and lowest temps seen in the image. So if the temp range is relatively narrow this can create the illusion that there is more heat leakage in some areas than there really is.
Also, heat loss is calculated as surface area multiplied by temp delta divided by r value. So, a small element like a 1 inch aluminum tube in a wall might be a significant heat leaker but because its a small surface area it really doesn't matter much overall.
This is not to say that rPods are well insulated, they're not, and won't be no matter what you do. Just consider the actual temp differences and surface areas and the effects of that before making decisions where to try to add insulation or otherwise change things. Go for the big hits first, like the reflectix in the windows. |
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Posted: 14 Oct 2018 at 10:33am |
Up until recently, the name of the game in thermal imaging cameras has been FLIR. Their lowest-cost cameras start at around $700 and go up from there. A lot. It's not hard to spend $2000 on a FLIR thermal camera. Way more than what I would be interested in for what would be a curiosity for the most part. However, a couple years ago, a company called SEEK Thermal came up with a thermal sensor that can plug directly into a smart phone (Android or iOS). They market this for around $200, and it seems like direct threat to FLIR, who has also come up with something they call the FLIR One. It is around the same price as the SEEK unit, but has much lower resolution. Software may be another issue.
Kevinscamps
Newbie Joined: 14 Jul 2018 Location: Fort collins, c Online Status: Offline Posts: 37 |
Posted: 15 Oct 2018 at 11:59am |
The camera I used probably costs around $300-$5000 bucks. We got it convince customers we know what we are doing.... Ha Ha Ha! |
Posted: 15 Oct 2018 at 12:16pm |
Yep, I've bought elaborate equipment for that purpose too. If you can't dazzle them with brilliance then baffle them with.... you know the rest.
I'll send you a PM. I have a 179 but the construction is the same and I'm trying to do some thermal calcs on it to estimate cooling load for an air conditioner conversion I'm planning. Thanks!
Kevinscamps
Posted: 24 Oct 2018 at 11:19am |
The door was a major weak point for insultion, particularly the door frame which has no thermal break. I added I made the existing screen door into a storm door by adding a piece of 1/8" lexan to each screen section. The cuts didn't have to be too accurate because the lexan goes almost 1/4" into the metal frame. It works to contain my child and prevent her from ruining the screen door. I will keep the bottom section in permanently and leave the top in just for the winter and spring for insulation. I also added 1/2" foam stuck directly to the door frame. It makes a huge diffence. When it gets cold again I will take some more thermal pictures.
Posted: 24 Oct 2018 at 11:52am |
Great idea.
rawest50
Senior Member Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Posted: 28 Oct 2018 at 9:34pm |
Was the thermal camera a high dollar camera? Looking at purchasing one for my iPhone.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. |
WinterSummerBliss
Newbie Joined: 06 Nov 2018 Online Status: Offline Posts: 1 |
Posted: 06 Nov 2018 at 3:16pm |
Awesome thermal camera pictures and analysis. Can you do this again on a cold evening? I'm curious what it shows.
