Page <1 45678 10> |
![]() Posted: 25 Sep 2018 at 3:44pm |
Thanks mcarter.
I was thinking also that the heavy appliances (fridge, heater, water heater), are also all on that side... I will for sure change out to D rated tires, Amazon has Carlisles for $50. Any brands you like particularly?
Offgrid,
Just thinking load bearing. I wouldn't worry about the slide on a 179 (albeit heavy) in a retracted position. Pretty much centered across axle load. The tires are a weak link but not substantial, always better to go with a better rating, in this case why many of us went to Ds vice Cs. My mere understanding of loads is once we retract, we center. A generality in trailers with slides. |
SH,
Interesting. I don't think you have an axle issue. It bothers me you say you have to release an auto adjuster to move a wheel and you have never reported heat. I think it is normal to see some play on the bearing with wheel attached. From a distance it's not easy to say why you don't see same on the faulty side. I am almost to point to come up and visit you in KY and see if we can figure this out. Sure we would have help. Let me know. |
Thanks Gents.
My experience with wheel bearings is that a slight wheel play is normal but I'll defer to mcarter on this.
StephenH, just for giggles, what axle do you have? Mine is Lippert variant number 165646. There is a really long part number as well, but Greg at Lippert used this variant number to look up the axle. Also, if I may ask, what load range tires are you running? If the Lippert axles are really good for 4400 lbs, then the weak link is likely going to be the tires, right? I also have a bit more wear on the edges of my tires. I'm still running the original load range C tires. I keep them at the specified 50psi max. I'm really curious now what the actual loading is on the slide vs door sides on the 179. Anybody have any ideas how to measure this short of getting hold of an expensive load cell? Thanks |
It has been a few days and I got busy so I had not posted earlier. It is interesting about the axle label stating 3500 lb when the parts support 4400 lb. Looking at my tire again, it may be that the wear I am seeing is a factor of load rather than axle bend. Although the inside edge of the tire is showing wear, so is the outside edge, just not quite as much. We have had several trips on this tire. I had replaced the door-side tire due to what I thought was excess wear, so it has many fewer miles than the slide-side tire. I jacked up the 'Pod to grease the axle and to check closer the situation. I noticed on the slide-side that the wheel has a very slight play in that I can feel a very slight movement when I try to move the tire right to left and up and down while the tire is off the ground. If what I have read is correct, this is normal. If I am mistaken, please let me know. OTOH, I did not notice this with the door-side wheel. The door side is the one where the self-adjusting brakes always seem to make the wheel too tight to easily turn by hand. When I grease the axle, I always have to loosen the brakes before I can turn the wheel freely enough to grease the bearings.
I don't know. Not sure what comment I would make. I have a Dexter axle and it's marked Surveyor. To date no issues with axle. I have a 2015 178. I do know it is a 3500 lb rated axle by the tags. If I was to order parts I would never check to see if another axle had the same parts to my knowledge there is no interchange info unless I stumbled upon it.
Well...here is an interesting update.
I pulled the part number on the 3500lb Lippert axle on my 2015 179, and called Lippert to find out if they made a bolt up higher capacity axle. The sales engineer said they should be able to configure a 4400 lb axle for me that would still use my existing wheels, but he wanted to confirm the exact configuration with his engineering staff. He checked with his guys (more than one apparently, to be sure they had it right) and called me back a few minutes later. He said that when they configured the 4400 lb axle all the parts were identical to what I already have, except that the label would state 4400 lb and not 3500... So, it looks to me like Forest River ordered an axle that could have been rated at 4400 lbs and rated it at 3500 instead. Pure speculation but can think of a couple reasons why they might do that. One is that the trailer frame is really the limiting factor in the design but they didn't want to call attention to that, so they derated the axle instead. Another is that they didn't want to advertise a trailer GVWR that high in order to keep the rPods slotted into the "liteweight" position in their product lineup. Hmmm...Any comments?
Thanks. I'll check it tomorrow.
SH,
I think I sent this link to you before, maybe wrong, very informative and simple. https://www.centrevilletrailer.com/how-tos/trailer-axle-alignment-trailer-tire-wear/ |
Here is a picture of the wear on the tire. On the inboard side of the tire, there is a pronounced step. When the trailer isn't up on the jacks, it looks like there is more bulge on the inboard side of the tire (driver's side) than on the outboard side and it did look like the tire was tilted inward at the top. I did not have any way to measure to see how much, but the wear is what is concerning me. ![]() |
Page <1 45678 10> |
