  New Posts New Posts RSS Feed: Water tank capacity and molding
Topic ClosedWater tank capacity and molding
 Post Reply Post Reply Page  <1 234
TheBum View Drop Down
Direct Link To This Post Topic: Water tank capacity and molding
    Posted: 17 Sep 2018 at 11:07am
Originally posted by furpod
You must have some pretty bad water.
Most water in Texas is pretty hard.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 17 Sep 2018 at 9:50pm
We are quite fortunate in northern Michigan.  Still have our original anode rod and it still looks almost new after 7.5 years.  Water stays in the tank from April through most of October before getting drained out.  With only a couple exceptions it has only seen our well water and the couple other times  received well water from other sources; never municipal water.
Direct Link To This Post Posted: 18 Sep 2018 at 2:02pm
Keith-N-Dar, to clarify,  the 6 gallons in the heater tank doesn't disappear, its just not accessible, and neither is the water in the lines.  Once the pump has pulled all 30 gallons out of the fresh water tank it will lose pressure and no more water will be available at the taps, leaving 6 gallons in the heater tank plus whatever is in the lines. So, if you pre fill the heater tank and the lines and then top off the fresh tank you will have 30 useable gallons. If you don't pre-fill, you'll have about 23.
