  New Posts New Posts RSS Feed: Hurricane Preparedness
Topic ClosedHurricane Preparedness
Direct Link To This Post Topic: Hurricane Preparedness
    Posted: 11 Sep 2018 at 7:31am
  Filling all three holding tanks with water would help to keep it from moving. Having been through several hurricanes living in south Florida for 55 years You can always determine the path the hurricane may take and move your camper close to a strong building on the leeward side if possible. If the eye of the hurricane is passing over you then you will get wind from both directions, if that is the case then I would hitch trailer up and head for Knoxville. Smile
2014 Ram 1500 Quad cab
TomBurl View Drop Down
Direct Link To This Post Posted: 11 Sep 2018 at 6:16am
Thanks for the reply.  I might be hitting the road with it... maybe take it about 6 hours west past Knoxville.
Tom Burlington
2107 R-Pod 179
2016 Nissan Frontier 4wd King
Direct Link To This Post Posted: 10 Sep 2018 at 11:05pm
God's speed to all in the path of hurricane Florence.  Get the heck out of the way as fast as you can and take your Pod with you.  At least its a home you know and like.
Direct Link To This Post Posted: 10 Sep 2018 at 9:02pm
My pod has been behind my TV regularly @ 65 mph and occasionally @ 70-80 mph. That being said, if you are in the path of Florence, I would consider a trip to Disney World or Niagara Falls for the next few days. BTW, if your Pod blows over, it's probably the least of your concerns.
Direct Link To This Post Posted: 10 Sep 2018 at 8:20pm
We had 70+ MPH last winter when our RP-179 was in the driveway. It's not exactly in the high wind area, but it got a serious dose of wind (it's partially blocked by our house from that direction). We did find a puddle under the fridge afterward. We think it blew in through the vents on the slide out, and ended up on the floor. It actually did better when we had the slide out extended. probably came through the same way, but ended up going straight down to the driveway.
I was a bit concerned that it might get blown over, as the wind was coming from the side.
Direct Link To This Post Posted: 10 Sep 2018 at 7:23pm
We have been through 60 mph gust with no problem/damage. Can't help with much above that.
Direct Link To This Post Posted: 10 Sep 2018 at 6:57pm
How much wind can my 179 withstand?  I'm sure a 60 mph gust won't bother it but what about a sustained blow of 120?  Any anchor system I might rig would likely get yanked right out of the ground.
Tom Burlington
2107 R-Pod 179
