Gary and Maureen ![]() Newbie ![]() ![]() Joined: 05 Aug 2016 Location: Wingham Online Status: Offline Posts: 4 |
![]() Posted: 03 Sep 2018 at 8:37pm |
Good evening all. Camping at Niagara Falls and can't get any power. Every time I plug the power cord into the outlet box it trips the switch immediately. Tried different outlets but always the same result. Tried flipping one breaker at a time but still the same. Any thoughts. Gary
Gary and Maureen Lisle
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2710 |
Check the voltage before you plug in again. |
Blender Bob ![]() Groupie ![]() ![]() Joined: 11 Mar 2018 Location: Colorado Online Status: Offline Posts: 48 |
Where is the switch tripping? On the Rpod? --> don't know. On the source power? If yes, check the grounding of the source. It could be that it is set up for a Marine, rather than a shorepower grounding scheme. In that case, the Neg and ground in the Rpod is causing a short to the source box.
Bob
2015 Chevy Colorado Z71 2018 178 R-pod Hood River Edition |
I've been told they turn the falls off at night? Maybe that' the problem?
![]() Hope you get it figured out, but I would be very careful without a ground fault detector or proper volt meter. fred
