  New Posts New Posts RSS Feed: Dometic 8501 Fridge problem
Topic ClosedDometic 8501 Fridge problem
Macdad View Drop Down
Direct Link To This Post Topic: Dometic 8501 Fridge problem
    Posted: 04 Sep 2018 at 12:40am
Problemed fixed. I traced the problem to no electric signal coming out of the Power Module circuit board in the "eye brow" panel above the door. There are 3 wires (white, black, purple) coming off terminal "X105" on the board. that go to the "burner control device" (gray box) outside. After unplugging the 3 wires, and trying to start it in the "gas" mode, I found no electricity in any combination of the 3 terminal strips.
     In the 8501 series, there are 2 type of boards, MES-older style, and the AES-newer style. Mine was the MES type. I fortunately found one at 1/5 the price of a new one $448. , used on eBay.
    I plugged it in, and it works great.
                           Macdad
Direct Link To This Post Posted: 26 Aug 2018 at 4:03am
Hi. I wanted to thank all of you for responding. As recommended , I purged my gas line by running the stove for several minutes , but still no spark nor gas valve turning on. I also have read all the other related posts. I really feel I have an electrical problem. While researching online I came across a helpful website that has a partial service manual for the 8000 series Dometic that I could download.    http://bryantrv.com/docs.html It has nice colored pictures and trouble shooting aids. It shows there is a 1 amp fuse on my circuit board (on top of fridge) that feeds the "burner control device" which feeds the gas solenoid and igniter. I was really hoping that I just had a blown fuse, but it was good. The manual also describes which lead to check for voltage ,etc.. It also goes over how to hold down at the same time both the "Mode" button and the "Temperature setting button" until all 3 Mode LEDs light up (gas ,12v,110v). Once they do you then push your temp button to make them light up. The number of temperature buttons lit correspond to service checks you are performing. I found this to be quite helpful , though I still have not solved my problem.
   One thing I think I need to check out, is that the porcelain insulator was broken on the igniter. I wondering if that could cause it to short out and not spark ; and maybe if does not spark, the gas valve won't open. Does anyone know? Has anyone had a similar situation. Thanks. Macdad
Craneman View Drop Down
Direct Link To This Post Posted: 25 Aug 2018 at 9:32am
I have a 2010 174 with the same problem, after a month in a factory authorized repair shop plus going thru all the suggestions given here on this site. I was not able to get I working on gas. It would light the go right out. Reconmadation for the rv repair shop junk it and put in a norcold refer parts are extremely expensive.i have gotten by 12volt on the road, 110 when at a full hook up and when dry camping I use the good old American stand by a ice cooler a easier and cheaper fix. By the way I capped off the gas supply line at the back of the refer, good luck
           Moe
Jo and Gary
2010 174
2011 Ford 150
mjlrpod View Drop Down
Direct Link To This Post Posted: 25 Aug 2018 at 8:39am
Does the fridge have one of the little igniter boards like the water heater has? That board seems to be a popular fix. Would be nice if that board worked for both, but i doubt that would be the case. Also, would it be ok to just hold a match at the venturi to lite it, and prove that it's just an ignition problem?
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
POD WE R View Drop Down
Direct Link To This Post Posted: 25 Aug 2018 at 8:38am
The  8501 has a defective gas valve that prevents it from lighting. My service man could not get a replacement valve so Dometic sent a new fridge under warranty.
Direct Link To This Post Posted: 25 Aug 2018 at 7:02am
If the fridge wasn't getting 12v, nothing on it would work, and it wouldn't work in any mode..since it does, we know it's getting 12v.
The biggest issue we see with "fridge on gas" problems, is line purging. Light the kitchen burners and let them run wide open for a couple minutes. Shut them off, then switch the fridge to gas and see if that works. It will usually make 3 attempts, over the course of a couple minutes, before it starts, or errors out.
Direct Link To This Post Posted: 25 Aug 2018 at 7:01am
Something may be preventing the gas burner from lighting,  be it a blockage or a mechanical problem with the burner.  Try searching the older posts on this topic.  There are many discussions that will give you useful hints.
Direct Link To This Post Posted: 25 Aug 2018 at 2:26am
HI . I am a new owner of a 2011 177. Everything works great, except I can't get the Dometic 8501 refrigerator to operate in the "gas mode". The refrigerator works fine on 110volts and 12volts. The trailer is level, gas cylinders full, batteries fully charged, When I switch to "gas mode" absolutely nothing happens, The solenoid gas valve does not turn on, and there is no spark at the igniter. I at first suspected what appears to be a gray plastic control box outside by the gas valve to be the problem. To test, I turned the refrigerator off and held the power button in for several seconds, I then set the control to the "gas mode" and immediately ran outside and checked with a 12volt test light all wires coming in and going out of the gray box while the fridge should have been going thru its start up routine. Again, it showed no electricity either coming in or going out of the gray box. Thus I wonder if the problem is elsewhere. I have not pulled the fridge out of its compartment. Does anyone know if there are any fuses in this system, other than the ones in the main fuse panel for the entire trailer ? If so , where are they located ? Has any one else experienced this same problem ? Any assistance would be greatly appreciate. Thanks, Macdad
