  New Posts New Posts RSS Feed: EscaPOD Adventures
Topic ClosedEscaPOD Adventures
 Post Reply Post Reply Page  <1 234
Keith-N-Dar View Drop Down
Direct Link To This Post Topic: EscaPOD Adventures
    Posted: 30 Jun 2018 at 12:51pm
"When you get up into Wisconsin and Minnesota, the soils are more sand than clay, and even with the more extreme temperatures they get in those states, the roads are a lot smoother."
That used to be he case.  We have had political events in Wisconsin that has resulted in deterioration of the condition of our roads as well as other things.  In spring when we went to Paducah the Illinois roads were at least as good as Wisconsin.  I hope our roads get the attention they need soon.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 01 Jul 2018 at 5:50pm
As I mentioned, we encountered some very rough roads in the upper mid-west. Once we got farther south, the roads got better. We were on the last leg to Asheboro, NC where my sister-in-law lives. Somebody passed us, honked, and pointed. I started checking mirrors to see what was up. It was a good thing that we were almost to a rest stop. The stress of the rough roads caused the black tank drain to come loose (Again!). When our escaPOD went to the factory for repair, the factory installed a second hanger. Unfortunately, it was of the same type as the first. The nylock nuts had come off both somewhere along the way and the end started dragging on the pavement. I don't know how since the handle is on the foreward side, but somehow beside losing the cap, the valve came open and the tank dumped on the Interstate. It is a good thing that sunshine is an excellent disinfectant. I feel sorry for whoever was behind us though.
At the rest stop, I closed the valve and used a number of zip-ties to strap the drain up. The good thing is that the valve was still capable of  shutting without leaking. I zip-tied a freezer bag over the end to take the place of the missing cover. We got the rest of the way to Holly Bluff Family Campground without further incident. However, our escaPOD had a certain "air" to it. It wasn't too bad and did fade over the next day.
After the funeral, we spent the night at the same campground. It was a nice campground not too far outside of town. It had a pool which we were not able to take advantage of on this short stay. I would like us to return there for a longer stay and to visit the NC  State Zoo in Asheboro while we are there. We arrived home and started the work of unpacking and getting ready for our next trip.
I ordered a new valve, drain, and cap from Amazon. It was tricky emptying the black tank so I could make the repair. Gorilla Tape helped. Still, the valve body did leak some also while it was open. Again, sunlight makes a great disinfectant. I used some bleach also. In addition, I fabricated a new hanger from strap aluminum. My hanger will NOT come loose. I should have done this the same time I did the one for the gray water tank, but I thought that having two of the other type would provide sufficient backup. Was I ever wrong! Live and learn!
Direct Link To This Post Posted: 05 Jul 2018 at 3:20pm
An addendum to the above post:
I sent a copy of the above post with pictures to Danielle Beber at Forest River. She replied that she would let the engineering department know that the supports failed and the fix I did to prevent this from happening again. Hopefully, this will lead to changes that will prevent this from being a problem on future R-Pods (and other Forest River brands).
