  New Posts New Posts RSS Feed: Backup cameras
Topic ClosedBackup cameras
AKPodGal View Drop Down
Direct Link To This Post Topic: Backup cameras
    Posted: 03 Jul 2018 at 6:34pm
Thanks for the replies. My intention is to use it primarily for backing up once the camper is hooked up. There is such a vast array out there (I’ve checked Amazon and etrailer), so I was hoping maybe someone out there had recently installed one. I only need one camera and prefer a dash mount.
Deb
DGH
crw8sr View Drop Down
Direct Link To This Post Posted: 03 Jul 2018 at 6:58pm
I found a wireless Peak brand at Menard's in the clearance pile.  $60.  Installed the camera on the license plate frame and wired it to the license plate light.  Turn on the parking lights or headlights and the camera is always on.  I like seeing what's back there.  When and if this one gives out I'll buy a better one.
Go for it!
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Ben Herman View Drop Down
Direct Link To This Post Posted: 03 Jul 2018 at 7:47pm
Deb
If that's all you need, then you shouldn't need to get too elaborate or pricey. Good luck with the search - hopefully installation won't be too tricky! When I installed ours in my wife's Ridgeline the receiver/screen just plugs into the cigarette lighter 12v but I had to hardwire the camera (wann't too bad, ran a line from the taillight compartment).
Tom A View Drop Down
Direct Link To This Post Posted: 04 Jul 2018 at 6:01pm
Can someone actually recommend a backup camera unit that they have used and found to be effective? Thanks.
AkPodGal
As mentioned earlier,I would talk to the folks at etrailer.com.  They have a lot of choices to meet your needs.
2018 Sequoia--2018 RP 190
Direct Link To This Post Posted: 04 Jul 2018 at 6:59pm
Almost all the cameras here are the same brand. Different models, but the comparisons seem valid.
Hayduke View Drop Down
Direct Link To This Post Posted: 08 Jul 2018 at 5:56pm
Originally posted by TheBum
Why not just test the turn signals, in which case you'd also be testing the brake lights? No tools required. That's what I do.
This method does test whether or not the tail lights on the camper are functioning (and for me, this is enough of a test mid-trip when I know all lights were working the day before).  It does NOT test whether or not the brake circuit is sending and receiving the appropriate brake signal.
2012 177 HRE
2017 Tacoma Double Cab
Direct Link To This Post Posted: 08 Jul 2018 at 6:09pm
There is an elegantly simple and low tech way to test the brake lights if you are alone and there's no one to tell you if they're on when you push the brake.  A simple stick cut to fit between the brake pedal and the front of your seat, such that the brake is depressed enough to turn the lights on works fine.  Push the brake, put the stick between the pedal and the seat front, then get out and look.  If the TV brake lights are on then the trailer lights should be too. If not, you may have a problem that warrants further inquiry.
Direct Link To This Post Posted: 09 Jul 2018 at 6:42am
The brake lights and tail lights are different circuits. Tail Lights are with running lights. Best to turn on tail lights - check - engage brake - check.
Here is pic of trailer side 7 pin, it is the RV Standard.
Sariian View Drop Down
Direct Link To This Post Posted: 09 Jul 2018 at 7:49am
I installed a Furrion FOS48TAPK-BL that I bought on amazon.  I wired the camera in to the middle running light at the top (camera comes on when headlights are on).  The screen mounts to the windshield via suction cup.  I use it for both backing up in to the campsite and often when driving since it gives you a much better sense of what traffic is doing behind you.
Its a few $$ but I'm very happy with the quality and glad I did it.
Ian
2018 RPod 176T
2017 Honda Pilot Touring
Anderson WDH
Sudbury, Ontario
