AKPodGal
Topic: Backup cameras Posted: 02 Jul 2018 at 10:18pm |
Anyone have experience with backup cameras? Since I will be camping solo most of the time, I’m thinking it would be a good idea to have one.
AkPodGal
DGH
Posted: 03 Jul 2018 at 12:30am |
Go to etrailer.com, search for trailer backup camera and then you can watch the videos and reviews. Many to choose from, with many options. I would go wireless. I like etrailer for getting info.
TheBum
Posted: 03 Jul 2018 at 11:21am |
They are a huge help when hitching up.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Happy Tripping
Posted: 03 Jul 2018 at 2:27pm |
AkPodGal |
I feel they're essential for solo travel, saves so much trial and error. That, with a stick marked to avoid a false hitch, and the same stick wedged in your car brake pedal to test the brake lights, while also you are testing the turn signals, and you are all set to go.
TheBum
Posted: 03 Jul 2018 at 3:48pm |
Originally posted by Happy Tripping
the same stick wedged in your car brake pedal to test the brake lights, while also you are testing the turn signals, and you are all set to go. |
Why not just test the turn signals, in which case you'd also be testing the brake lights? No tools required. That's what I do.
Alan
Three cats
Posted: 03 Jul 2018 at 4:03pm |
Some folks use the security fob. Unlock or lock the vehicle blinks the brake lights.
AKPodGal
Posted: 03 Jul 2018 at 5:08pm |
Can someone actually recommend a backup camera unit that they have used and found to be effective? Thanks.
AkPodGal
DGH
Posted: 03 Jul 2018 at 5:16pm |
I understand that. However technology changes quickly, so I am reluctant to recommend what I did three years ago for you today. I'm not going to update unless necessary. Good luck.
Ben Herman
Posted: 03 Jul 2018 at 5:46pm |
AkPodGal |
Mine's too old to use as a reference point, so am reluctant to recommend it - I would suggest spending some time on eTrailer and Amazon, and see what the current stuff is like. Lots of things to consider - where/how you'll mount the screen, removable vs fixed, size, one camera or two (some folks like to have one on the back of the trailer also, to see where you are backing once hitched up vs just using it to hook up).
TheBum
Posted: 03 Jul 2018 at 6:08pm |
I'm using the factory backup camera in my Highlander from 2012 on a head unit from probably around 2014, so it's not going to be of any help either.
I assume you're needing one with a monitor. Do you have any preference whether the monitor mounts on the dash or becomes part of the rear view mirror? Systems are available either way.
Alan
Three cats
