  New Posts New Posts RSS Feed: NOISY AC has to go
Topic ClosedNOISY AC has to go
fixedwing2 View Drop Down
Direct Link To This Post Topic: NOISY AC has to go
    Posted: 30 Jun 2018 at 7:37am
We have a 190 that we mostly like, but if I can’t find a quieter AC it’s going up for sale. Any ideas. I’ve been wearing ear plugs, but that’s not a good long term solution.
Steve Young
R Pod 190
Cessna 150M
Direct Link To This Post Posted: 30 Jun 2018 at 7:56am
There are a few things you can do. First is to set the fan speed to low. The constant some is easier to get used to than to have it cycling on and off and between low and high speed. Second is to remove the inside shroud and use spray glue to glue closed cell foam on the inside. Third is to close the big vent and use the end and side vents. All these will make it a bit quieter, but the constant low speed is the best.
Direct Link To This Post Posted: 30 Jun 2018 at 8:10am
We’ve been using the constant on low speed and that certainly less shocking than the”jet engine “ kicking on every few minutes and we’ve tried different vent openings. I’ll try installing foam, before I sell it or get out the saws-all. Thanks
Steve Young
R Pod 190
Cessna 150M
Direct Link To This Post Posted: 30 Jun 2018 at 9:00am
It's a small space, and your head is always pretty close to the outflow.. Hard to quiet down much. A few have switched to a smaller a/c unit, like the Cub 9.5.. cheaper then a whole new camper.. But any small camper with a non-ducted a/c is going to be loudish.. maybe my time on tanks has made me more tolerant of the noise.. to have a/c  Smile
Direct Link To This Post Posted: 30 Jun 2018 at 10:35am
I was afraid there wasn’t much we could do. I’ve been around tractors and airplanes almost all my life so I’m used to constant noise, but I would rather not try to sleep in them. Thanks anyway.
Steve Young
R Pod 190
Cessna 150M
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 30 Jun 2018 at 10:41am
The air con is worse, but wait until it starts getting cold and you begin to use the furnace!  Most people get used to the noise eventually.  A smaller air con unit would probably help, as Furpod suggested, but I'm not sure what you can really do in a little box like an RPod.
Direct Link To This Post Posted: 30 Jun 2018 at 1:43pm
For the furnace, set the fan to auto so the AC fan won't come on when the furnace turns on. Then get a small fan such as one from O2 Cool. Run that to both provide cover sounds and to help circulate the heat. That is what I do.
marshel View Drop Down
Direct Link To This Post Posted: 01 Jul 2018 at 6:15am
Atwood Air Command units are supposed to be quieter with a bonus of being more efficient
Tom A View Drop Down
Direct Link To This Post Posted: 01 Jul 2018 at 5:49pm
I have a 190 as well. There is only one fan speed--yes,I called the dealer.  It's noisy no matter what.
2018 Sequoia--2018 RP 190
Direct Link To This Post Posted: 01 Jul 2018 at 6:52pm
Okay. I looked on Forest River's web site at the virtual tour of the 190. It looks like you have a different thermostat than I do. Check out this YouTube video on how this new style works. It actually is similar to the older-style one I have. Do you have a model number for the thermostat? With that, you could look online for specific instructions.
