Awchief
Topic: Install - Lippert Solera Slider Awning Posted: 28 Jun 2018 at 4:05pm |
I got a couple of quotes from local shop to install a topper. They both wanted right at $250 just for the installation. The video makes it look very easy. I am inspired to give it a try. Thanks for the link and inspiration.
Michael
Posted: 28 Jun 2018 at 12:37pm |
Saw that. Not offered by etrailer. Did see a video on a DYI cover made from vinyl gutter. The Solera Solar Shield appears to be aluminum and built into fabric.
Posted: 28 Jun 2018 at 12:07pm |
Lippert calls it the Solera Shield. From their brochure:
The built-in Solera Shield is available on replacement slider and patio awning fabrics. It provides elegant and practical protection for your Solera vinyl or acrylic awning canopy. As the awning retracts, the aluminum Solera Shield automatically rolls up around the fabric to protect it against the elements during travel. Be sure to order your Solera Shield to match your hardware.
Posted: 28 Jun 2018 at 11:57am |
It does not nor have I seen that option.
Posted: 28 Jun 2018 at 11:56am |
Mike, Does that have the cover over the fabric? Is that an option?
Posted: 28 Jun 2018 at 9:44am |
Looks good Mike. A great mod. Anything that is dual purpose is a winner, slide top stays clean, and protects from rain/water intrusion..
Posted: 28 Jun 2018 at 8:30am |
Here pic after install.
Posted: 28 Jun 2018 at 8:26am |
I purchased a Lippert Solera Slider Awning from etrailer.com and installed yesterday. The install was done on a 2015 178. The slider measured 73" from outside frame to frame. I chose the 6 1/2' awning which at 78" gives you 2 1/2" on each side. The awning was less than $200, free shipping. The larger the slide the more the price, for a 179 is north of $300 because the 179 has a much larger slide. The install took less than 2 hours and DID require help of a second person when putting poly cord in the keder rail. I chose white versus black just because I thought it would be cooler. One caveat - the awning comes with all hardware to include a awning rail (keder). I did NOT use it - I used the existing rail on my Pod. I did have to remove the drain spouts on Pod. I have added a link to the etrailer video on install of same awning on RP-180, good to have because install instructions supplied do not cover install on an existing rail.
Link: https://www.etrailer.com/tv-install-solera-slide-topper-2017-forest-river-forester-lcv000165063.aspx
