Page 12> |
Author | ||
![]() Posted: 23 Jun 2018 at 8:51am |
Watch this video: https://www.youtube.com/watch?v=jpUrkmAmz5g This truck is a 2000 F150.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2702 |
You probably need a relay and a fuse. Some Fords had the wiring and components in the glove box, others it is inside the passenger kick panel. GM did same thing, has the wiring but the fuse has to be added. There is a F150 Forum that is very informative, but a quick stop at a dealer would probably get you an answer. Just because you have a trailer tow package doesn't mean that 12V wiring is hooked up. I read somewhere once that dealers leave that wiring out because the 12V pin in the 7 way can corrode if not used. I don't know. Was your 7 pin connector dealer installed?
babyboogerfamily ![]() Newbie ![]() ![]() Joined: 05 Mar 2018 Location: VA Online Status: Offline Posts: 36 |
I have a 2001 Ford F150?
fognet ![]() Newbie ![]() ![]() Joined: 21 Jun 2018 Location: MO Online Status: Offline Posts: 10 |
I wired my own and placed the big fuses that are required. Keeps everything charged
The world is a book and those who do not travel read only one page.
James Fredericktown, MO 2019 RP 176. Previous RP 180. TV Toyota Highlander. 19 MPG while towing. |
+1, wired and capable are 2 different things. I know with my GM products I had to a fuse to the under hood fuse box. The wiring was there but the fuse is an addition even if the trailer harness is OEM added. It's a 40A fuse that goes in that charge circuit. Just because you have a factory installed 7 pin doesn't mean you have a charge capability. As you look at your 7 pin on vehicle it will or should have 12V at the 1:00 position. It should follow alternator output.
If the 7 pin hookup is properly wired your vehicle will charge the R-pod battery.
That's not good. You need to check that out. The capability is there, perhaps your tow vehicle is the culprit. I know with some GM products it was necessary to add a fuse. But I think you want your TV to charge your TT batt.
The hookup from the vehicle doesn't charge the battery. Learned that the hard way. Not on our model anyways.
Page 12> |
