Tom A
Topic: Trailer Ball height advice Posted: 10 Jun 2018 at 9:59am |
My new TV sits substantially higher than my previous one that the dealer setup with the ball mount. In looking at the ball mount instructions, it says to measure the height of ball coupler when the trailer is level and add one inch to that to determine the correct ball height setup. Is that STOP around here? The lowest I can get the dealer supplied ball mount puts it two inches higher than the coupler. The dealer will swap it out for me, but that's a four hour roundtrip.
2018 Sequoia--2018 RP 190
Ben Herman
Posted: 10 Jun 2018 at 10:15am |
Not sure about that 1 inch calculation (others more knowledgeable will chime in) but no need to make the 4 hr trip; ball mounts are readily available at any decent rv shop and not very costly. Easy to change out the ball.
Guests
Posted: 10 Jun 2018 at 10:44am |
Really need to know if you have a WDH or just a shank and ball. If the latter, Walmart has a variety of balls and different 2" shanks - straight and up to 4" drop/rise (at my local store).
You'll want your trailer to be level or, even better, slightly lower at the tongue, when fully loaded for travel.
Posted: 10 Jun 2018 at 1:39pm |
+1 to David's post. You want to be slightly lower at the tongue. We started our measurement at dead level and then subtracted 2" so that the tongue would be lower, this substantially helps reduce sway as well.
Leo B
Posted: 10 Jun 2018 at 2:02pm |
Same her , we use the 4" drop on our F-150. Tows great!
Tom A
Posted: 10 Jun 2018 at 2:36pm |
Thanks folks
Posted: 10 Jun 2018 at 3:58pm |
etrailer sells a very good adjustable height ball hitch, I use it and recommend it. You can change your ball height to make it level.
Tom A
Posted: 10 Jun 2018 at 5:43pm |
Originally posted by mcarter
etrailer sells a very good adjustable height ball hitch, I use it and recommend it. You can change your ball height to make it level. |
Hah! I just got off the phone with Sami at etrailer, and she came up with the perfect solution.
Thanks again.
john in idaho
Posted: 10 Jun 2018 at 6:18pm |
most any U Haul store has all kinds of hitch supplies. I must have 5 or 6 "stingers" with 2" balls mounted. Each TV /trailer hookup is different. I have always preferred the Balls with a hole for a cotter pin on the bottom after mounting it in the stinger. Just further assurance, or insurance, if you will.
