  New Posts New Posts RSS Feed: Water
Topic ClosedWater
flat6s View Drop Down
Direct Link To This Post Topic: Water
    Posted: 25 May 2018 at 5:27am
Mcarter,
No offense taken sir.  Just good conversation amongst friends,
Best of luck...Joe
Direct Link To This Post Posted: 24 May 2018 at 4:40pm
flat6,
Sorry Flat6 is was in reference to a previous post and I thank you for your detailed response. Absolutely agree with cleaning water tank I also am very aware of water tank maintenance, thanks for taking time to respond, no offense meant.
Direct Link To This Post Posted: 24 May 2018 at 4:09pm
I like the idea of the tablets. I've ruined more than one pair of pants by splashing bleach. Also, I think I'd rather (after showering) smell like "swimming pool" than "Clorox". I planned to go to Walmart in the morning anyway so, I'll see what they have.
As mentioned, I take "bottled water" for consumption. It's cheap and I keep it on hand anyway (for consumption), as I don't drink my well water at home. It is also a backup water supply for emergencies, in case of a power outage. Neither of my 2 generators will deliver 240 volts to power the well pump, at home.
While we have strayed from the OPs question, the comments are good. Many conversations drift away like that. However, to address the OPs question, I do not drain my water heater - other than when winterizing. As mentioned, it is the wind resistance that hurts most regarding fuel mileage. I can't imagine 50lbs. making much of a difference.
Also, I'm wondering to myself why I am taking the advice of someone who is telling me to put poison in my water????
Direct Link To This Post Posted: 24 May 2018 at 1:50pm
And one more thing, of course
Remember.. chlorine, bleach or HTH, is poison.  You are putting poison in your drinking water.  And that effects each individual differently.  Be careful what you put in your drinking water.  This is not a good place to take guesses or to risk a mistake.  This, if for no other reason, is why my recommendation will always be, drink bottled water.....it is safer.....
Direct Link To This Post Posted: 24 May 2018 at 1:33pm
There is nothing wrong with Chlorine Bleach.  It will loose effectiveness somewhat over time.  It is the additives that are put in the bleach that become the problem.  Scents and fragrances,  Color enhancer and protectors etc.  If you are using unmolested Chlorine Bleach in the correct ratio, that is fine.  The reason we had to dump the tanker where bleach was used was because of the additives.  So, make sure you are using a high quality straight chlorine bleach, if that is the route you choose to go.    Like I have said all along... Everyone sees it different.  I am not trying to convince anyone of anything.  I am only sharing my opinion.  And as we know, everyone has at least one opinion on every topic.  So please, if it makes sense to you, then good.  If it does not make sense to you, then good.   Joe
Direct Link To This Post Posted: 24 May 2018 at 1:25pm
Also keep in mind that carbon filters take out the remnants of the chorine or ammonia sanitizing agents in municipal water so you're effectively putting in water in your tank with no disinfectant at all.  If you read the wording on the filters it doesn't say it removes all the bacteria, it says it "greatly reduces" sediment, bacteria, etc.  It all depends on what bugs are in the water and whether they can get by the filter.  Some bad bugs are smaller than 100 microns.
I used a filter recently to fill our tank because of the high level of arsenic in the water, but now I'm stuck with a filter that I can't adequately dry out.  I left it out in the NV sun to bake.  But it'll never be used for water to drink.
If you've got a really good immune system, and don't mind a little diarrhea from time to time, tank water is fine.  It's all a matter of risk vs. benefit.  When we're in México, I frequent the street vendor because the food is absolutely delicious.  [I look for a lot of turn over in product.]  Generally, I'm fine since my gut is already probably loaded with the bugs from the food and I'm used to it.  But when it doesn't work out, there's always diphenoxylate hydrochloride and atropine sulfate aka Lomotil®.
Direct Link To This Post Posted: 24 May 2018 at 12:52pm
The Camco filter I specified does state on the label that it does filter out bacteria. However, it also states to not use on water that is not microbiologically safe. At home, we are on city water that is treated with chlorine or chloramine. I don't use water from sources I don't know or trust. I drain the water from the filter when I remove it and cap both input and output openings to keep dirt and anything else out. The information I have read indicates the KDF keeps bacteria from growing in the carbon filtering media. Camco also says it has a 100 micron filter. How effective is the KDF part?
I have sanitized at the beginning of each season. I have been drinking water from the tank with no issues. I don't drink from the hot water side though.
xfitpanther View Drop Down
Direct Link To This Post Posted: 24 May 2018 at 12:50pm
What is different about HTH vs Chlorine Bleach?
David
2017 r-Pod 180
Direct Link To This Post Posted: 24 May 2018 at 12:32pm
Originally posted by flat6s
HTH is a chlorine that is used to sanitize water.  It is used in swimming pools, we use it to sterilize new water main that has just been installed, we use it to sterilize our tapping equipment that taps water main.  We use it in tanker trucks that provide fresh water during a disaster, such as a tornado.  One time we had an employee dump bleach into a tanker of water.  That cannot be consumed.  We had to dispose of that and rinse the tank.  HTH tables or liquid can be purchased at Walmart or just about anywhere that sell small kiddie pools.  HTH tabets are the easy to use.  Probably 2 to three tablets will treat the 30 gallon of water in you fresh water tank and make it safe to drink.  Without the bleach smell.  Taking a shower in bleach water is not good.  Drinking bleach water is worse.  Again...the easy solution is to drink bottled water, IMHO.
I thank you for allowing me to express my opinion.....Happy Trails
Joe
Thanks for the info! I'll take a look at Walmart and see if they have some HTH. I seem to recall hearing something negative about bleach a while back. I already knew not to consume it. Bleach water really dries my skin after a few days of use!
Again, thanks for sharing your knowledge & experience.
Direct Link To This Post Posted: 24 May 2018 at 12:31pm
the HTH is located in stores where the swimming pool supplies are
