  New Posts New Posts RSS Feed: Power drills for levelling
Topic ClosedPower drills for levelling
Direct Link To This Post Topic: Power drills for levelling
    Posted: 23 May 2018 at 8:11pm
I have used my trusty Dewalt drill  for several years now, never had a problem
Direct Link To This Post Posted: 23 May 2018 at 8:16pm
Have to agree with Happy and lostagain.  I use the crank away method, it is good exercise and helps to keep the "pipes" mean and lean.
Direct Link To This Post Posted: 23 May 2018 at 8:37pm
LOL
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 23 May 2018 at 8:40pm
This is what my tongue jack looks like now.  I ground off the rivet holding the handle on and pushed it out.  Then I took a 3/4" nut and drilled out the threads so that the nut would fit snug on the top of the jack screw.  Before slipping the bolt on, I very carefully drilled a hole right through the center of a flat face of the nut and through the center of the opposite face.  The hole was sized to take an appropriately sized roll pin.  (I don't remember what size, but I don't recall spending a lot of time thinking about it.  It must have been the same diameter as the rivet that held on the crank.)
That done, I slid the bolt on the jack screw, tapped in the roll pin, and finally ground off the ends of the roll pin flush with the faces of the nut. Voila.
I still carry the crank around with me in case this thing fails.  And of course I have the socket and a ratchet in case my drill or it's battery ever quit on me.  That hasn't happened in the 4 or 5 years since I made this mod.  I used to use an 18v DeWalt but now I have a 20v DeWalt drill, both of which work(ed) fine.  This is a job for a drill with some torque, especially raising the trailer and the back of my TV enough to attached the Fastway friction bars.
A store-bought 12v tongue jack looks fancy, but I really can't imagine that it works any better than this, plus I have a drill that gets a lot of other use.  A side benefit is that not having a ready go crank on the tongue jack at least arguably makes the Pod a little harder to steal.
Direct Link To This Post Posted: 23 May 2018 at 10:17pm
Craneman View Drop Down
Direct Link To This Post Posted: 23 May 2018 at 10:26pm
Jo and Gary
2010 174
2011 Ford 150
Direct Link To This Post Posted: 23 May 2018 at 10:35pm
         https://drive.google.com/open?id=1XWHvjlnRisYOS6hzctlvGm6I3EH6OY1D
Copied marwayne a couple years ago works great
Jo and Gary
2010 174
2011 Ford 150
