  New Posts New Posts RSS Feed: What is this connection?
Topic ClosedWhat is this connection?
Olddawgsrule View Drop Down
Direct Link To This Post Topic: What is this connection?
    Posted: 23 May 2018 at 12:40pm
Originally posted by StephenH
The picture in question does not resemble any of the "resettable fuses/breakers"  pictured in the Wikipedia or Google search articles. I still say it is most likely a bridge between two blocks.
Well, the picture in the link I sent is real close to exactly what I'm looking at. I'm heading back under there to look again for a part number.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 23 May 2018 at 12:47pm
Okay. I see now to what you are referring. I was looking at the copper strip. While the copper strip is most likely a bridge, you are asking not about that, but about the terminals under the strip I think. In that case, it does resemble one of the self-resetting breakers, but it is hard to tell for sure. A part number definitely would help.
Direct Link To This Post Posted: 23 May 2018 at 12:58pm
Got under there again. It's a Short Stop 12v 30amp resetting breaker.
Think I'll be able to move my legs again in a couple days.. LOL
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 23 May 2018 at 1:00pm
The copper bridge confused me as well. Why? Two separate lines in to two separate lines out.. I'm certain there's a reasonable explanation out there somewhere..
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 23 May 2018 at 1:20pm
I think one would have to trace the wires to see where they go to get a better idea of what they are protecting. Thanks for looking. I learned something. I had to put one of those in the engine compartment of the Escape when we installed the brake controller from the battery to the connector on the 12V power line. I just was not seeing your picture right and thought you were asking about the copper strip, not what was under them. My apologies for my confusion and causing you to get under there again. Hopefully, someone will be able to explain why the bridge is there.
GCRicker View Drop Down
Direct Link To This Post Posted: 24 May 2018 at 10:15am
Thanks for looking Olddawgsrule. I couldn't find a label, but maybe I didn't crawl under far enough. I agree with StephenH, the bridge is a mystery also.
