Page <12 |
![]() Posted: 11 May 2018 at 11:21am |
The Camco 40578 Single Tank Cover is the one I have.
Larry-D ![]() Senior Member ![]() Joined: 12 Oct 2017 Location: Middle TN Online Status: Offline Posts: 113 |
Look on the back of the hard plastic one. There may be a nut on a bolt that is connected to the regulator to hold it inside the cover.
Bailey ![]() Newbie ![]() Joined: 08 May 2018 Online Status: Offline Posts: 10 |
There is a small bolt on wing nut holding regulator to side of cover. Do I take that off or leave reg attatched. Thx much.
I have a small screw coming out of back of my cover.Looks like it holds the regulator. It is attatched to inside of my black cover. A wing nut holds it on outside. Do I disconnect it. I need to remove cover to fill tank. Thx.
Another example of a post that starts with an issue, then switches to a different subject. If the issue you have is NOT about the OP, then start a new post. We're offering suggestions to two different issues. Too confusing and not worth suggesting to.
Bailey - I would start taking apart until I figured it out , then recall how I did that in future. Multiple manufactures and different products, I appreciate the suggestions and the fact folks are helping, without knowing what you have it is a crap shoot. This one reason the Advanced Search has issues. |
lgblau ![]() Senior Member ![]() Joined: 09 Feb 2018 Location: Arizona Online Status: Offline Posts: 140 |
+1 Mike.
Leonard🌵
2017/179 2017 Ram 1500 |
Sorry, that should have been a separate topic.
No biggee SH.
I removed the wing nut attatched to back of frame holding tank and the cover lifted off easily. Thanks for the advice.
Page <12 |
