Page <1 2345> |
![]() Posted: 04 May 2018 at 8:56am |
Glueguy - I appreciate this discussion and apologize for being over zealous. It won't happen again. I was wondering if we can do a little test with your F150? If your trailer is not connected and you go into your "Towing Status" and get the screen where the gain readout is on the left hand side - Do you get a display that says "No Trailer Detected"? I realize this is completely different than the Trailer Disconnected in other displays. If you were to connect a trailer I think the display will change and you will get the gain readouts as set. The "No Trailer Detected" is a standard, especially for Tekonsha designed TBCs, which I believe Ford is. Thanks.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
I did these tests.
So the "Trailer disconnected" message comes in 3 different cases, 2 of which are when I am manually squeezing the trailer brake. The other "Trailer disconnected" message when there is no trailer actually connected. I could not simulate the broken tail light situation, but when we pulled the 4-pin from the connector and stepped on the brake I got a message about a malfunctioning tail light. Just a side note. Some of the above required me to cycle the ignition. The truck appears to re-assess the trailer status after the ignition has been turned off/on. |
Thanks Glueguy, appreciate the info. That system for a Ford I think is very informative. Not only tells you when there is a electrical connect or light issue, but also when the trailer brake circuit is working. Learned something from this.
PodWa ![]() Newbie ![]() ![]() Joined: 11 Oct 2016 Location: Cheney, WA Online Status: Offline Posts: 36 |
TRAILER BRAKE PROBLEM RESOLVED! There was a bad electrical connection at the driver's side backing plate. The technician replaced the crimp-on connectors at that location and now everything works perfectly. As I suspected, this problem was related to the backing plate replacement done a few weeks before our last trip, and the repair was at no cost to me.
Wow! That was not something easy to find as it would have looked just fine visibly. You got a good technician to figure that one out.
I'll be darn PodWa. Appreciate the response.
When the problem started I visually checked the connectors that the technician replaced and they looked good and seemed to be firmly crimped. There must have been some internal fault that i could not see. I am fairly proficient in electronics, but I don't know much about trailer brake systems and don't have a wiring diagram of the R-Pod 179, so my ability to troubleshoot the system was limited. It only took the technician about 20 minutes to find and correct the problem, and he traced everything front to back. I am extremely grateful that the fix was so easy. We were in and out of the shop in about 45 minutes.
I have to give kudos to Blue Dog RV in Post Falls, Idaho, and their facility in Fife, WA. Both were very polite, helpful, and actually listened to my description of the problem before jumping to expensive conclusions. There are lots of complaints on this forum about bad service at selling R-Pod dealers, but this is certainly not one of them. Happy camper here!
Good to hear the problem has been fixed!!
Me too, Leo! It seems my problem was similar to yours, but mine was created during the backing plate replacement. You got it right, and now I know where to look if this happens again.
One thing I found helpful is making a 1/4" spade jumper wire. If your TT battery is connected you can take your 7 pin plug (trailer side), looking directly at it, with the alignment lug in 12 o'clock position. At 11 there is 12 Volts. Using your jumper you can jumper that 12 volts around the plug to test 12 volt circuits. At the 5 position is ground, don't jumper to there. So the brake issue for example: You can jumper 12v at 11 to the blue brake control at 7. You could then go back to axle and test blue wire that controls brakes. Or even check the 12V is getting to that brake. I carry that pin diagram with me and the jumper, without a TV I can check the running and tail lights, the brake lights and turn signals my add on reverse lights etc. Just with one jumper.
Page <1 2345> |
