  New Posts New Posts RSS Feed: 179 slide motor location
Topic Closed179 slide motor location
lgblau View Drop Down
Direct Link To This Post Topic: 179 slide motor location
    Posted: 05 May 2018 at 11:09am
Okay, I give up. Where is the slide motor in my 179. Thanks.
Leonard🌵
2017/179
2017 Ram 1500
Direct Link To This Post Posted: 05 May 2018 at 11:11am
There are two slide motors. You will need to fold back the rubber seal just above the top track on either side of the slide out to get to the motors.
Direct Link To This Post Posted: 05 May 2018 at 11:20am
Thanks StephanH, but I do not see anything like you described.
Leonard🌵
2017/179
2017 Ram 1500
Direct Link To This Post Posted: 05 May 2018 at 11:52am
Thanks again StephenH. I found the motors. You were right onSmile
Leonard🌵
2017/179
2017 Ram 1500
Direct Link To This Post Posted: 05 May 2018 at 8:56pm
You're welcome. They are hard to see. That's for sure.
Direct Link To This Post Posted: 05 May 2018 at 9:45pm
Mine has a controller under the fridge with instructions on what to fo if the slide fails. To bad the factory installed it upsidedown, and at the very bottom. Hard to read and hard to follow the directions. At least I now know more thsn I did this AM.
Leonard🌵
2017/179
2017 Ram 1500
Direct Link To This Post Posted: 06 May 2018 at 7:37am
The controller for mine is in the same place. I don't know if it is upside-down though as I haven't looked at it. I'll wait to do so because that panel below the refrigerator has been a problem and I now have it anchored pretty well so I don't want to take it loose to look.
Direct Link To This Post Posted: 06 May 2018 at 10:45am
Yeah, mine did not go back on well. Giant wood screws thru metal frame equals one time use. At least I now know what is down there.
Leonard🌵
2017/179
2017 Ram 1500
