ouR escaPOD mods |
Page <1 1617181920 58> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6431 |
![]() ![]() ![]() ![]() Posted: 29 Apr 2018 at 9:44pm |
Sounds good. Have a safe and fun trip.
Thanks, you too.
geewizard ![]() Senior Member ![]() Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
I just finished my install just as Fred did above but used this https://www.amazon.com/gp/product/B007VAXQF8/ref=oh_aui_detailpage_o05_s01?ie=UTF8&psc=1 Otherwise, I followed StephanH's method. Works great. |
I wish I had found the one you got, geewizard, from Amazon. It's a better deal than the one from HD.
The newest addition to our towing equipment is a Hensley Cub. This hitch normally sells for over $2500, but Hensley is having a special, offering a significant discount as they are introducing the Swift Arrow and Swift Cub models. These new models use chains and a snap-up bracket to set the weight distribution instead of the jacks to do the job.
I originally ordered the Swift Cub. I installed it and found that there were things about it that made it less than desirable for us. In addition to the chains and snap-up bracket and lever, it has two support rods that are used to hold the spring bars while the chains are disconnected, stabilizing the hitch so it can be set for easier hitching and unhitching. These are less expensive to manufacture but for someone with arthritis, dealing with the pins, bars, and chains is more of a problem. I ended up exchanging the Swift Lift Kit for the standard jacks. They are a lot simpler once set up as one only has to deal with the hex nut on each jack to adjust the spring bars. I did a short test drive with the chains/snap-up brackets, and then another with the jacks. There is no noticeable difference in performance. Both are a big improvement over the Equal-i-zer. There is no movement of the trailer and the hitch is virtually silent. I could not hear any hitch noise--no bumping, groaning, squeaking or popping. ![]() Is it worth it? If it makes my wife and me feel more secure while towing, it is. I also expect that because of the way it works, it will be better at keeping us stable in conditions which might be too much for a friction-based sway control system. I returned the cover. It did not fit to my satisfaction. I will make a cover. I have some ideas about how to do it. Since the hitch stays attached to the trailer except for the hitch bar, I locking it two ways. First is the hitch coupler lock. The second is to bring the chains up through the Over Center Latch (OCL) bars and locking them together with a heavy-duty padlock. While these are not foolproof, when coupled with the fact that not too many people have Hensley hitches, it is likely to baffle the opportunistic thieves. A couple of pictures and I have to run. We have to leave shortly. ![]() ![]() |
DavMar ![]() Senior Member ![]() ![]() Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Stephen,
Please post a review on this WD anti-sway hitch after you used it for a couple weeks on your trip. Looks interesting. |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
Addendum to the Hensley Hitch mod above: I really did not like the factory cover. To me, it just did not fit correctly. $85 is a lot to spend for something with which I was not satisfied, so after an exchange that verified that it was not just one that was cut wrong, it went back for refund. I decided to make my own. It is not as heavy a fabric as the Hensley factory cover, but it uses material I already had on hand from my previous awning and slide-out cover projects It isn't a simple box since there is a taper. However, it is very box-like. I used grommets so I could use bungee cords to hold it in place. This was a quick fix. I may like it enough to keep using it or I may decide to make a 2.0 version sometime down the road.
This one is a small one with some creative recycling. The Hensley hitch specifies greasing the WD bars every 500 miles. The problem is that of how one carries a grease gun without having a big, greasy mess from leakage and without getting grease all over things where it does not belong. Since I had done a previous modification to make a larger sewage holder carrier, I realized I had a suitable candidate for making something to hold the grease gun already--the original sewage hose carrier.
The original carrier was 26" long, which was too long for the grease gun. While extra space would not have been a problem, it would not have worked where I wanted to mount it which was under the Stromberg-Carlsen Trailer Tray and allow room for the door to open without blocking the ability to remove the propane tank cover. When I knocked it off one time and broke the mounts, I had ordered replacements. However, one time previously, I had also gotten a replacement door that broke and that came with a mount also. Since the mounts were glued on to the tube with ABS cement, it would not have been possible to remove the mount without breaking it. Since I had a spare mounting bracket, I decided to cut the tube to the length I wanted (21") which was enough room for the grease gun to fit with a little room to spare. I taped a piece of paper around the tube so that I could get a straight line for the cut and then used a hacksaw to cut it to length. Using ABS cement, I glued the new mounting bracket on and VoilĂ ! a grease-gun tube. ![]() ![]() It is long enough to hold the grease gun, wide enough to carry a spare tube of grease, and short enough so that I can open the one door to get to the grease gun when needed. |
Hensley Cub and towing day 2 of long trip.
I should have gotten this hitch when I bought our RP179. Towing is a dream! It isn't that I don't feel trucks passing or the effects of a strong cross-wind. It is just that it is much more predictable and there is not that little wiggle as they pass. Some trucks have come up alongside without me knowing. Others, like RVs with the flat front or busses do give the trailer and truck a little push, but there is no wiggle to it. It is more of a straight-line push, easily dealt with with very minor steering adjustments. I'm still working on getting the WD dialed in, but even so, towing is good and more relaxing than with the Equal-i-zer which, in turn, was more relaxing than no sway control. So far on this trip, we are averaging a little better than 12 mpg. That includes the Appalachians, the Ozarks, and a strong head/cross wind today ahead of a front that was coming through. We are in Alabama tonight and expect to be in Oklahoma tomorrow. It should take another couple of days to get to our younger daughter's house in Arizona where we will spend several days and likely make a camping trip with her to Sedona if she can get reservations. |
