  New Posts New Posts RSS Feed: Air in the lines..??
Topic ClosedAir in the lines..??
Olddawgsrule View Drop Down
Direct Link To This Post Topic: Air in the lines..??
    Posted: 29 Apr 2018 at 2:27pm
Rainy day today so setting my computer station in Lily. When it slows a bit I'm working on shore water.
Getting quite a bit of air in the lines. Went out and blew off the safety value on the hot water tank to insure it's full. Spitting air..
I don't have my basic tanks loaded. Curious if required (thinking shouldn't but what the heck do I know??)
Do have the pressure regulator hooked up.. thinking it may be my issue..
Ran back through all my connections.. Looks good and tight (sealed).
Thoughts???
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 29 Apr 2018 at 4:05pm
Well.. you have to bleed out several gallons of air to clear the lines and WH..
Direct Link To This Post Posted: 29 Apr 2018 at 4:11pm
+1 - get it running on city water, purge all the lines. Then move to fresh water tank and using the water pump, the pump takes time to prime.
Direct Link To This Post Posted: 29 Apr 2018 at 4:48pm
+1 Likewise. The water heater is a 6 gallon void. There will be considerable air (like 6 gallons worth) before there is water.
Direct Link To This Post Posted: 29 Apr 2018 at 4:57pm
Okay I shall. Just seemed to be quite a bit and got nervous.. Will go back to it.
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 01 May 2018 at 3:57pm
Well... After several hours of running I decided to fill some water into the fresh water tank and try it. No Joy.
The valve was the wrong way! The valve had not been switched from winterize.. I did't think that would mean anything when on Shore water, but I guess it does.
No more air in the lines and Full Joy!
I assumed, and we all know what that means... I will winterize this year and bring it off. That issue is in the books!
Byways no Highways
2017 Tacoma
Truck Camper Build
