  New Posts New Posts RSS Feed: Bed Shelf
Topic ClosedBed Shelf
Ben Herman View Drop Down
Direct Link To This Post Topic: Bed Shelf
    Posted: 23 Jun 2018 at 10:36am
Originally posted by Billy Bob
I've got some cypress flooring ill use...run it through a planer glue together and install......bed, dinette, bath, and outside.
That sounds like nice stuff. I used hemlock, key is to get the shelf as light as possible. I used lauan mahogany underlay plywood (3/16") with 1/2" board for edges/sides. Even full-width shelf doesn't weigh much.
Billy Bob View Drop Down
Direct Link To This Post Posted: 23 Jun 2018 at 9:06am
2019 RPOD 190
2017 Chev Colorado 4 X 4
Yellow Lab and English Springer Spaniel
Retired Coastie View Drop Down
Direct Link To This Post Posted: 21 Jun 2018 at 6:56pm
Measured and made my own. One out of walnut the other cherry. Watched the outside of the camper to locate the studs to attach the shelves. Made a cherry one for the bathroom too.
DavMar View Drop Down
Direct Link To This Post Posted: 27 Apr 2018 at 8:08pm
Originally posted by mcarter
DavMar,
Looked at the wood shelf today at Lowes - 75 bucks, I also wanted the over bed light to be somewhat functional. I felt the wire shelf provided more light through to sleeping area.
I was in my Lowes today too and they didn't have the wooden shelf in stock. There answer as always at this store....you can order it, ugh! After looking at all the shelving material with the wife were more incline to go with the metal one now as you have. They have the advantage that you mention plus lighter weight. A win, win, I'd say.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Direct Link To This Post Posted: 27 Apr 2018 at 4:17pm
DavMar,
Direct Link To This Post Posted: 27 Apr 2018 at 3:53pm
I just removed my valances so don't have a photo of them installed - but basically they use metal angle brackets (the same ones that FR uses as drawer pullout limiters - if you look in the drawers you'll see what I mean). One side of the bracket is attached to the wall with 2 - 5/8" screws, and the other side with 2 - 5/8" screws to the inside of the valance. Not terribly sturdy. Hard to get to the screws to remove the valances, had to get on my back on the bed with a drill with a long Phillips extension.
Direct Link To This Post Posted: 27 Apr 2018 at 9:27am
Thanks everyone for your inputs on how you did this shelving mod, just keep them rolling in! At $75 for a wooden shelf it makes pause and think maybe wire might be the way to go, don't know? I'll have to take a hard look at the valances and how they attach if anyone has a photo of that they can post it would be appreciated. Again thanks for all the great suggestions!
wonder dog.
2017 Rpod 180
Lexington, NC
Direct Link To This Post Posted: 27 Apr 2018 at 9:23am
The interior panel is not fiberglass, but is thin lauan plywood with a wallpaper cover. If you use an expanding anchor, (make sure it is less than 1" in length or you will experience outer wall puncture (ask me how I know Unhappy). Fortunately, when the R-Pod went to the factory for repair, they replaced that side so no more puncture evidence. Thumbs Up
Ghosthawk View Drop Down
Direct Link To This Post Posted: 27 Apr 2018 at 7:07am
Thought about attaching an L shaped piece of wood the length of the shelf with Command Strips.
Unsure how much load it would handle.
I have expandable shower curtain rods in my Amazon Basket, should take more load properly installed and should do no damage. But it is a more costly option.
If I could be sure I would hit the aluminum frame I would drill it and put in an anchor. But not sure I want to trust my wifes packing them full to just a few screws into fiberglass panel.
Direct Link To This Post Posted: 26 Apr 2018 at 9:55pm
The shelf itself is not that heavy. Metal shelving would be heavier I think. The wood used for them is very light but the shelf seems to be quite sturdy. Mine rests on the valences, but the command strips I have do support some of the weight as well. I don't load it down with heavy items. Other than my CPAP machine, the baskets we have on it hold my clothing as my wife uses the wardrobe drawers for hers. A lot of items either go in the wardrobe on th ecloset rod or on a separate rod that Iuse in the TV to carry any hanging items that won't fit in the wardrobe.
