  New Posts New Posts RSS Feed: Wheel Bearing Maintenance
Topic ClosedWheel Bearing Maintenance
Direct Link To This Post Topic: Wheel Bearing Maintenance
    Posted: 23 Apr 2018 at 5:04pm
Originally posted by David
I use a product called "Wheel Bearing Grease" from NAPA auto parts. It comes in a plastic tub - kind of like "Country Crock" or "Cool Whip".
I'm all set to service mine....I just need the weather to cooperate.
Please allow me to amend this:
"Wheel Bearing and Chassis Grease" Part #75-601
https://www.napaonline.com/en/p/NO_75601
seafans View Drop Down
Direct Link To This Post Posted: 23 Apr 2018 at 9:09pm
The Wheel Bearing and Chassis Grease Part #75-601 is made by Valvoline and it is a paraffin base grease.  I did not find any particular grease spec such as NLGI#2, so it could be "cool whip"  If you can find someone local that sales AMSOIL products the Synthetic Multi-Purpose Grease is the way to go.  This grease will not separate or liquefy and seep through the wheel seal seals.  If you have the Leppart 10" hubs on your R-pod the seals might be 10-19 NAPA part number.  They have the same numbers on them as the manufacture.  Net price is about  $2.29.
rawest50 View Drop Down
Direct Link To This Post Posted: 23 Apr 2018 at 10:22pm
How do you install on the hub. I looked and I have a chrome dome cover on the end of the axle. Does ithe cover pop or screw off? Then what? Snap on or screw? I had a boat long ago and they just snapped on and we’re spring loaded. These look a 100 times better.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 23 Apr 2018 at 10:36pm
The hub pops off.  The axle nut is held in place by a bent washer, at least on ours, rather than a cotter key.
TheBum View Drop Down
Direct Link To This Post Posted: 24 Apr 2018 at 11:17am
If you're using the zerk fitting to regrease, make sure you use a grease with a red lithium base so that you don't end up mixing different types. The grease I use is the Lucas "Red-n-Tacky".
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
DavMar View Drop Down
Direct Link To This Post Posted: 24 Apr 2018 at 3:33pm
Is it the older axles that you manually have to pack the grease in the bearings because I thought the new axles has a zerk fitting to re-grease them with a grease gun?
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Direct Link To This Post Posted: 24 Apr 2018 at 3:40pm
Good question, I think fact is some members choose to hand pack rather than use Zerk. Personally I use the zerk.
Direct Link To This Post Posted: 24 Apr 2018 at 7:06pm
Ours was manufactured January 2011 and came with the zerk on the axle.  I have done it both ways, first couple times manually by hand and for the past 4 years using the zerk.  We use a grease with graphite in it.  The salesman compared it to the Amsoil grease, which we used to use.  Amsoil is an excellent grease, this IMHO is even a bit better (produced by Chemsearch) however, if you are going to be on a regular schedule greasing (which you should be) this is a mute point.
malkbean2 View Drop Down
Direct Link To This Post Posted: 25 Apr 2018 at 6:58am
Some greases are incompatible. Does anybody know what the manufacturer uses?
Direct Link To This Post Posted: 25 Apr 2018 at 7:33am
Ours had a build date of 10/10, and it had the ez lube.
