Forum Home Forum Home > General Camping > Cook'n With Gas
  New Posts New Posts RSS Feed: Best barbecue for RPoddingl
Topic ClosedBest barbecue for RPoddingl
Direct Link To This Post Topic: Best barbecue for RPoddingl
    Posted: 12 Apr 2018 at 9:20am
Do an advanced search on "Post Images". Most of us use postimage.org. Once in post image. Select image size (800X600). Select removal time. Open pic source. Choose image. Go to "Hotlink for Forums". Click on Blue Folder icon. Indicates copied. Return to post - Control V, you can copy one image at a time.
onazip View Drop Down
Direct Link To This Post Posted: 12 Apr 2018 at 8:07am
Cry  I used Google Photos and the are blank.  I'll figure it out.
2018 Tundra
2018 176t
Direct Link To This Post Posted: 12 Apr 2018 at 7:59am
If the regulator is not built in, you just need the connecting hose. From the AUX connection on Pod to the regulator connection on grill.
Direct Link To This Post Posted: 12 Apr 2018 at 7:54am
how do i post a pic?
2018 Tundra
2018 176t
Direct Link To This Post Posted: 12 Apr 2018 at 7:47am
actually, the regulator is not built in.  it came with the grill but you have to screw it on every time you want to use the grill.  I'll figure out how to get a picture on here.
2018 Tundra
2018 176t
Direct Link To This Post Posted: 12 Apr 2018 at 7:40am
Originally posted by onazip
Can the Coleman roadtrip grill be hooked up directly to the propane connection on the R-Pod?  So we wouldn't have to use the small, disposable propane tanks.
You can buy an adapter hose that will feed it straight from the 20 pound tank, using a splitter valve, OR, you can modify the grill to accept low pressure to run it from the Pod's low pressure port, if your Pod has one.
Splitter Valve. You will then need a 20lb to 1lb adapter hose.
Convert to low pressure.
Direct Link To This Post Posted: 12 Apr 2018 at 7:27am
Are you talking about the AUX Propane Connection on the R-Pod? If so it is low pressure. You can't connect a grill with a built in regulator to the line, in other words you can't regulate twice. You have to modify grill connections to eliminate the regulator. CAMCO makes an adapter that allows you to run off your on board tank, by adding low pressure and high pressure ports in line with your present propane system, I use that as I don't have an AUX Propane connection.
Direct Link To This Post Posted: 11 Apr 2018 at 9:39pm
2018 Tundra
2018 176t
Direct Link To This Post Posted: 24 Jun 2016 at 8:40pm
+1 for the Weber Q
Direct Link To This Post Posted: 24 Jun 2016 at 8:30pm
Weber Q - BTW  made in America.
