ilthyn ![]() Groupie ![]() ![]() Joined: 21 May 2013 Location: Alberta Online Status: Offline Posts: 64 |
![]() Posted: 19 Mar 2018 at 5:33pm |
Hi All
Opening my fridge door has become a bit of a problem. It is necessary to lift up on it while pressing the two buttons on top. Is there some kind of adjustment I can make? |
Is it possible that the hinges have loosened? If so, can you get to them to tighten them?
You may also want to try some silicone spray to lubricate inside the latch / under the buttons. And if you tighten the hinges make sure they are aligned correctly so the latch comes together correctly.
