shicks
Topic: Add Propane Quick Connect Posted: 20 Mar 2018 at 12:24pm |
I would like to add a propane quick disconnect, installed on the door side of my 178. The link below shows what I'm hoping to install (or similar).
I want to tie into the low pressure side and I know my grill/firepit needs to accept the low pressure (not have its own regulator).
The propane line going back to the hotwater heater is accessible on the slide side. Just after the axle is a connector from flex to rigid that I could change to a T. It is in the perfect spot with a direct shot between the water tanks to the door side.
While I understand the mechanics (and use of yellow tape, etc.), I'm unsure of the best hose (flex or rigid), connectors to use.
I've searched here for propane, quick, connections, etc. not finding any posts.
Anyone done this and have suggestions?
Thanks!!
RP 2014 178/Grand Cherokee/E2 WDH/Prodigy P3
Mods: Solar, lowes shelves, sink-out, dual batts/propane, steps, door window, EMS, glass stove top, tires, Microair EasyStart... it doesn't seem to end.
marwayne
Posted: 20 Mar 2018 at 12:45pm |
I used a flex hose and added a second regulator.
Posted: 20 Mar 2018 at 6:24pm |
Nice job Marwayne, excellent craftsmanship.
Leo B
Posted: 20 Mar 2018 at 6:39pm |
Ditto! Really nice work!
shicks
Posted: 20 Mar 2018 at 9:29pm |
Thank you Marwayne!! Is what I'm looking for. If I could ask a few questions:
Did you cut/make the flex out to the quick fitting? Or did you find one the correct length?
Do you have a recommendation for place to purchase (if not Amazon)? We have a fairly friendly plumbing warehouse nearby... I might find the fittings there?
Thanks again.
marwayne
Posted: 20 Mar 2018 at 10:08pm |
I went to Mutual Propane, they had all the stuff I needed and made the hose to the length I needed.
Artypod
Posted: 18 Jun 2018 at 10:30pm |
Shicks, did you end up finishing this mod? I would like to do the same for my 178
rawest50
Posted: 19 Jun 2018 at 4:59pm |
My 179 came with a quick disconnect. The POD has a regulator and so did my gas grill. Will not work. Two regulators cut the pressure way down. I purchased everything to tee off before the regulator and still maintain the regulator for the POD. I have not made those mods yet. I am planning on adding a 2nd tank and will do it then.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
shicks
Posted: 21 Jun 2018 at 2:36pm |
ArtyPod: I haven't done this mod yet (so many others first!). I want to, just would rather have a shop make the connections and haven't had time to get to one.
