List Your Mods:
 Post Reply Post Reply Page  <1 1112131415 78>
Brent S View Drop Down
Post Options Post Options   Quote Brent S Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 30 Sep 2018 at 3:17pm
I really like the idea of raising the bed for more storage and will look into that possibly.
I started working on the trailer tongue today.  It had only one battery and gas tank so today I cut off the battery and tank mounts and ground down the weld spots.  I had to make a larger battery rack to accommodate the batteries I just got as they were about an inch wider than the original rack was.  I will post more progress as I go, but for now I just got it all cleaned up and ready to weld the new mounts on.
Hmmm, I’m new to the forum, and my Rpod, but just tried to add a photo here.  Is there no way to upload a picture in my iPad here?  I’m good at restoring and building things but am seriously lacking in my tech skills!
Woodmiester View Drop Down
Post Options Post Options   Quote Woodmiester Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 1:25pm
I have done the following to our 190:
1.  Added a full width towel and wash cloth cabinet to the rear wall of the bath. (12"X30")
2.  Turned the small wardrobe into a pantry closet by adding shelving.
3.  Curtained all windows.
4.  Added shelving to both the foot and head of the bed.  (16" on the foot and 6" on the head.)
5.  Hung a collapsible clothes rod on the angled wall between the bath and bedroom.
6.  Installed Hinges on the dining "flip up" access to storage space.
7.  Installed covers on the open trailer frame in the rear.
8.  Opened the storage area under the kitchen sink for storage.
9.  Enclosed the open side of the bathroom cabinet.
Swampfox
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 8:45am
I had originally used the valences for the majority of the support. When I noticed them being pushed down, I changed to anchors. I did not want the shelf to come down on us while we were sleeping.
Kup-Pod View Drop Down
Post Options Post Options   Quote Kup-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 6:24am
Well anchors it is then! :-)  Thanks very much for the insight and advice.
2017 RP-178
2021 F150 5.0l
"Lead me on a level path"
Ben Herman View Drop Down
Post Options Post Options   Quote Ben Herman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 10:41pm
Originally posted by StephenH
Your shelf and pantry shelf mods look really good. I would consider using anchors (1" or less) to attach the bed shelf to the wall. Eventually, the weight of the shelf will start to push the valences down Anchoring directly to the wall will help prevent this.
Agree with StephenH on this; in my case, I removed the valances as they really don't serve any purpose and just got in the way of attaching the shelf.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 9:18pm
Post Options Post Options   Quote Kup-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 9:10pm
When we purchased our Rpod, my wife made me promise not to do any mods for at least a year.  Well two weeks before the year I started building our first mods.
#1 was a shelf above the bed (idea stolen from Stephen H's EscaPOD mods).  Instead of buying the shelf from Lowes, I built one using birch 1x1 frame with 1/4" thick slats from Home Depot.  I could not get the Sherwin Williams stain match posted on this site since there are no paint stores in our area that match stain anymore (weird!!).  After much trial and error and sweat, I found out that a first pass of MinWax Classic Grey #271 followed by a pass of MinWax Dark Walnut #2716 provides a pretty good match for the 2017 dark brown/grey cabinets.
It was also difficult to get the shelf above the valences on the 178 because the bed is directly behind the washroom and the slide out.  If I keep the slide out in, I can shimmy it is up there with much "manipulation".  A couple of screws will hold it in place but the valences are providing the support.
#2 mod was a narrow shelf unit between the fridge and the dinette.  I had about 8" to use and still have about 3/4" to spare.  I used 1/4" birch plywood (finished both sides) and it has plenty of stability to hold dry goods and some pantry type stuff.
There will be more to come, next job is to extend the length and depth of the two kitchenette drawers.  Another idea "stolen" from the forum! :-)
We're pretty pleased with the results, let me know your comments!
2017 RP-178
2021 F150 5.0l
Andy View Drop Down
Post Options Post Options   Quote Andy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 1:39pm
If you want to send me your e-mail address I will be happy to send it to you.  I'm still new to this site so don't know how to send photos (tech challenged!).
jud.anderson@yahoo.com
2017 179
2016 Silverado Z71
Subzilla View Drop Down
Post Options Post Options   Quote Subzilla Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 1:08pm
Andy, you any pics of your sink removal??  I really want to do this but my wood (interior modification) craftsman skills are not as developed as my mechanical skills.  Would just like to see the final product.  Thanks!!
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Andy View Drop Down
Post Options Post Options   Quote Andy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 4:57pm
Same thing happened to me!  So I took out the sink, cut the drain, then used a 1/4" piece of plywood that was 11.75" x 20" so I could screw it on into the existing holes with the screws.  I drilled another hole in the bottom left side so I could also attach there.  I painted it with primer and two coats of oil based paint that I had mixed that matches well.  Once the panel was installed I sealed it with almond silicone caulk, painted the screw heads and was done!  We really like the extra space with the sink out.  enjoy!
2017 179
2016 Silverado Z71
