Page <1 4567> |
![]() Posted: 16 Mar 2018 at 11:23am |
So, since it was Friday, and the weather is nice.. I did some experimentation. If I remove the outer collar, and mount the lock to it, I can wobble the lock quite a bit. But, that's because of free play with the narrower hasp point.. ![]() So, looking at it.. my $.05 fix. (it actually took $.10 to make this perfectly snug) in this setting. Again, for whatever reason, (manufacturing tolerance stacking I am sure) Ours is perfectly tight when assembled and mounted. ![]() ![]() ![]() They could be held in place with a drop of super glue or silicone, heck, even duct tape.. |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Online Posts: 2709 |
A penny or two or three might be cheaper!
Could also just put a slug from an electrical box in there too. Probably cheaper than a nickel. |
I suppose, if you wanted to splurge, some combination of penny, nickle dime would get the very best snugness.. but who knows how much $$$ you might be out in the end... ![]() |
henryv ![]() Senior Member ![]() Joined: 09 Feb 2017 Online Status: Offline Posts: 259 |
Ingenious! You guys are cheap!
I found the perfect solution. I had a couple of small round magnets that stick to the steel. Also sprayed the lock with some Blaster silicone lubricant and it works smoother.
I often put several drops of anti-seize into the lock mechanism of locks that live outdoors. Better locks made of stainless might not need it, but if there are any steel components inside, it will keep them moving smoothly. One word of caution, anti-seize contains graphite, and it will turn everything it touches black (but you can wipe it off). The nice thing about graphite is that it will stick once the liquid carrier evaporates.
DaveB1701 ![]() Newbie ![]() Joined: 24 Jun 2021 Location: Green Bay, WI Online Status: Offline Posts: 36 |
2021 R-Pod 171
2017 Chevy Colorado Z71 V6 Just me & my pooch Mr. Buster... |
IMO, the best trailer tongue lock is the one made by Proven Industries.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3345 |
+1 Purchased ours 4 years ago. Not cheap but I agree with GG - it is the best out there.
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
Whats wrong with a Master lock through the hitch latch?
John
'16 R-Pod 180 |
Page <1 4567> |
