sean p
Topic: Anode rod Posted: 01 Mar 2018 at 7:45am |
Does the hot water tank ever need flushing out. and if so whats the best way.
2016 179pod--BETTY
2010 nissan frontier
Sean and Doug
Butchie the morkie
touring the west
SC for Huskers
Posted: 01 Mar 2018 at 9:08am |
 My 2017 R172 is over in the homeowners lot. Would the name plate on the heater tell me what size anode to order? Thanks Guys and Gals
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Posted: 01 Mar 2018 at 9:12am |
Yes, you should flush out your HW tank when you winterize or un-winterize. If you leave the anode port open all winter, then you never know who took up residence in the tank and may want to wash out whatever settled in. Depending on the mineral content and filtration of your water, "stuff" (mostly calcium carbonate) accumulates in the tank and it's a good idea to wash it out. You can just use a hose spray nozzle or you can get one of those little flexible plastic wands that they sell on e-trailer. If you use the latter, be sure you don't mix up the one you use for your black water tank with the one for the HW tank. You'll be amazed/appalled at what you'll see coming out of your HW tank.
Posted: 01 Mar 2018 at 11:03am |
Suburban Part # for an anode rod is 232767.
ron_whitt
Posted: 01 Mar 2018 at 11:11am |
I leave my anode rod out all winter, but I seal off the vent opening with a plastic bag. I rinse out the hot water tank in the fall while winterizing and again in the spring while de-winterizing. Just in case of "critters..."
Ron & Shirley
2020 Tacoma
2012 177 rpod
Posted: 01 Mar 2018 at 11:18am |
I put a pipe plug in it, just a turn or two.
Posted: 01 Mar 2018 at 11:27am |
I rinse with the little wand thing in the fall, then just remount the anode. Good for the next year. Well.. now I just put the plug back in. Furpod² doesn't use an anode.
Leo B
Posted: 01 Mar 2018 at 11:28am |
+1 with Mike. We do flush it out at the end of the season.
