  New Posts New Posts RSS Feed: Texman 182g Mods
Topic ClosedTexman 182g Mods
 Post Reply Post Reply Page  <1 1718192021 33>
texman View Drop Down
Direct Link To This Post Topic: Texman 182g Mods
    Posted: 28 Feb 2018 at 1:24pm
Went ahead and replaced the tires to D rated Carlisle
And mounted the battery disconnect and added another Zamp port or 12v outlet
TexMan 2015 182g
2018 Sequoia
TexManMods
voisj View Drop Down
Direct Link To This Post Posted: 12 Feb 2018 at 11:18pm
Originally posted by texman
voisj
I wanted to mount my battery cuttoff like yours, but didnt have the tools to make a hole that big and not sure what to use anyway.  the steel box i have is very hard to cut.  What did you use to make the hole?
Texman,
I used a regular hole saw going slow with oil, took awhile but worked. You could drill a small 3/8" hole and then use a jigsaw because the hole doesn't need to be perfect Since the square plate on the switch covers the holes edges. I put a good bead of silicone on the back of the plate before I screwed it on.
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 12 Feb 2018 at 10:33am
brake controller installed.  Looks nice i think.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 12 Feb 2018 at 10:24am
a few more pics  I managed to get the battery boxes inside the box, just no lids.  i used a 2.6 cu ft box and i think that most are 2.75cf.  If you want to use the box for storage, get the bigger box for sure. I actually found a use for the worthless sewer hose holder-floormat storage.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 12 Feb 2018 at 10:22am
This is what i came up with to remount the battery box after having to move it because of the WDH. no room to spare.  I think i got really lucky that this actually worked out.  I remember looking at the others that have done this mod and didn't consider how tight all this is.  The only problem is that i have to remove the tank cover to get to the latch for the battery box.  Not a big deal since the only thing in there is batteries and no room for anything else anyway.  I used 1.25" tubing and my nutsert tool to mount to the frame and then used 1/4" stainless bolts to mount it all up.  I also had to reposition the safety brake by just turning it 90 deg to the inside, which isn't ideal, but should still work in case it ever happens.  Now i am ready to try the e2 on a trip this weekend i hope.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 12 Feb 2018 at 10:08am
voisj
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 11 Feb 2018 at 8:25pm
Amazon. I can send the link if you need it. Easy to install too and still wotking good.
TexMan 2015 182g
2018 Sequoia
TexManMods
ZuBrew View Drop Down
Direct Link To This Post Posted: 11 Feb 2018 at 7:53pm
Nice job on the mods. Where did you get the bug screens?
2017 Chevy Silverado 1500 4X4
2018 R-Pod 189
2013 Yamaha FJR 1300A
Direct Link To This Post Posted: 11 Feb 2018 at 6:59pm
 More Mods:
Quote.
Added box for batteries from etrailer.  (Tried Harbor Fr, but they couldn't seem to get the toolbox and would not sale the display. Fine.) paid more, but it is a really nice box except for drilling holes.  The box is perfect for the batteries less the plastic boxes.  Anyone see a problem not using the plastic boxes?
Texman,
Here's my new 6 volt set up (finally killed the g24's).
I used the plastic boxes and just screwed them down to the bottom of the box as the easiest way to keep them secured. As I also put other things in the box i didn't want anything to puncture the batteries or hit the posts and ground them out. Just got back from 4 days camping and they lasted straight through!, love it so far.
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 11 Feb 2018 at 11:16am
i have this brake controller and an the Fastway E2 6000#gtw  600#tw to install next. if anyone has tips on either of these, please let me know.
That looks like a decent TBC, but I have no experience with it.
As for the E2, google for WDH setup, and look at a few setup videos on youtube. You will get the idea. You want a significant portion of the tongue weight shifted forward to the front wheels of your TV. The actual amount will depend on the TT and TV requirements, and there is more than one way to measure it. Most people just measure the height at the top of the wheel wells to ground. The most accurate way is to actually weigh the front wheels, back wheels and TT wheels to see where the weight has gone. That is also the most time consuming, and in most cases unnecessary. After it's all said and done, "some" of the tongue weight will be taken off the back wheels of the TV, and shifted forward to front wheels of the TV. As a consequence a very small portion of the weight will be back-loaded to the TT wheels. Because of the relatively long moment arm, the actual weight shifted back to TT should be really small; on an R-pod it will be something in the neighborhood of 40 or 50 pounds.
