  New Posts New Posts RSS Feed: Generator, water heater, solar panels - ?
Topic ClosedGenerator, water heater, solar panels - ? - Event Date: 09 Dec 2017 - 09 Oct 2018
lwilsn628 View Drop Down
Direct Link To This Post Calendar Event: Generator, water heater, solar panels - ?
    Posted: 08 Dec 2017 at 5:16pm
Hi
New owner of not- quite new RPod 181G, which I tow w a Honda Ridgeline.  So far so good.
Question:  I cannot for the life of me locate the hot water heater, to drain it for winter (not a huge deal yet as NM weather has not turned cold).  I have opened every opening and cannot for the life of me find what I think the thing should look like.  Can one of you more experienced folks point me to it?
Also -- we are considering buying ourselves a generator as a Christmas present. I looked at local Cabelas and most are heavy (>100 lb) which is more than I want to be trying to manipulate into a tow vehicle.  There is also a 2000 watt one at about half that weight.  What is the experience of  the group with generators -- size etc -- and suggestions for manufacturer?
Lastly -- what about solar panels?  Do any of you use them?  If yes -- what size etc?
Thanks!
LWW
Direct Link To This Post Posted: 08 Dec 2017 at 5:31pm
Welcome to the group! Congrats on your 182!!
Direct Link To This Post Posted: 08 Dec 2017 at 6:04pm
Welcome and Congratulations!
For the water heater, you will need to look for the hatch on the outside. It should be toward the front on the slide side. Look for a rectangular hatch with a turn-ring catch.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 08 Dec 2017 at 6:16pm
I hAVE a set of folding aluminum ramps I bought for  loading equipment onto the truck.  I roll my 100 pound gen set up the ramps and it stays there for the trip.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 08 Dec 2017 at 6:44pm
Hi and thanks for your response.  Maybe I am just not recognizing the heater as I have been in that space. Hmmmm.  Will have to open it up and look at it again.
LWW
mjlrpod View Drop Down
Direct Link To This Post Posted: 08 Dec 2017 at 6:50pm
The external hot water tank cover is usually a square metal cover.  It normally will have a series of small round or square holes in it to exhaust the heat.
Generator? I just bought two  2000 watt hondas to run in series. dont know yet how they will do, but, Honda is among the best, and it weighs only 46 pounds each.
I have no solar experience or advise.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 08 Dec 2017 at 7:12pm
Search Google images or YouTube for rpod water heaters.  There's a lot of good info there.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 09 Dec 2017 at 7:48am
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
dr2428 View Drop Down
Direct Link To This Post Posted: 09 Dec 2017 at 7:53am
You're looking for something like this, the water heater panel is poorly highlighted, and may be black.
2017 RPod 179
2018 Chevy Colorado Z71 4x4
Direct Link To This Post Posted: 13 Dec 2017 at 3:36pm
Thanks to all responders -- Merry Christmas and best wishes!
LWW
