Page <1234> |
![]() Posted: 08 Dec 2017 at 6:12pm |
Moderator, can you set up a forum for engineers to argue about technical details? All it seems to be doing here is confusing those who haven't already tuned them out.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2719 |
The bulk/absorb/float voltage levels between wet SLA, gel SLA, and AGM SLA batteries is not all that different. |
WillThrill ![]() Senior Member ![]() ![]() Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
This is the link to that thread, which is still 'active'. The other link I posted earlier is to a thread on how to connect a 100 watt solar panel to your Pod's battery, particularly if you have a Zamp port. Basically, all you do is run a set of inexpensive battery clamps from your tow vehicle to a charge controller (between 10 and 30 amps) and then run another line to the Pod's battery from the charge controller either with another set of battery clamps or by plugging into your Pod's Zamp port if it has one. The gauge wire needed depends on both the amperage of the charge controller and the length of the wire, but if each length is no more than 10 ft., 16 or 18 gauge wire is fine (my 10 amp charge controller came with sufficient lengths of 18 gauge wire). Then you just start the car and let the charge controller gently and safely charge up your Pod's battery. A simpler approach is to use jumper cables, but this is not as healthy for deep cycle batteries, which are designed to be charged in a slow, controller manner, which jumper cables absolutely cannot do. But in a pinch, they will work as well.
2014 Hood River 177 2005 GMC Envoy XL |
Scroll back up to his response, where it says "this thread' it's a link. |
Little oops there, '100w' system..Nice though. PWM controller that's 30a. Room to add another panel (or 2) with changing the PWM controller. |
Hayduke ![]() Groupie ![]() Joined: 03 Apr 2012 Location: Salt Lake, UT Online Status: Offline Posts: 68 |
Friends don't let friends buy zamp... |
2012 177 HRE
2017 Tacoma Double Cab |
JET ![]() Groupie ![]() Joined: 13 Jan 2017 Location: Ashland, Oregon Online Status: Offline Posts: 72 |
Thanks everyone for the input. Will...could you direct me to the thread you are referring to about using the charge controller, which is something I am totally unfamiliar with.
John |
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Jet, This 100 amp system (edit. 100watt)from Renogy is a deal and a good place to start if your elec usage is low and there is sun. Mine recharges my batteries fully every day in the summer, not so much in the winter. If you really plan for a week or two off grid You may need more like 200 watt system and /or a small inverter/generator that can be used to charge the batteries. or like Will said, use your tow vehicle to charge. rgds John
john in idaho ![]() Senior Member ![]() ![]() Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
They make Zamp solar panels right over the mountain from you in Bend. I understand they have sales from time to time.
https://www.solarblvd.com/products/solar-cynergy-160-watt-foldable-12-volt-solar-panel-2/
2012 177 HRE
Page <1234> |
