Page 12> |
Lakeway Rpod ![]() Newbie ![]() ![]() Joined: 15 Nov 2017 Location: Texas Online Status: Offline Posts: 7 |
![]() Posted: 15 Nov 2017 at 1:41pm |
Hello out there. Just received my 2018 Rpod 178. So fun. For some reason the water heater using propane stopped working. I can heat water using electricity, so the heater works. One note, the DSI light next to the water heater switch in the unit stays on. Any ideas? Thanks so much!
That would indicate an ignition failure. If it is convenient for you to get back to the dealer, take it there and have them fix it under warranty. Otherwise, try the reset buttons that are behind the cover. I don't know if that will help, but it can't hurt.
I'll take it for granted that you checked to see that you do have propane in the tank and that the valve is turned on. |
Thanks so much. There is propane and it's on. I tried the reset as well. Still does not work. As it turns out, I called the dealer right after my post and I will be there tomorrow.
I really appreciate the quick response!!!
Larry-D ![]() Senior Member ![]() Joined: 12 Oct 2017 Location: Middle TN Online Status: Offline Posts: 113 |
Try unplugging the controller board, wait a few seconds and plug it back in. Our larger trailer had a bad board from the factory and with distance and aggravation it was cheaper to order a new board from Amazon and replace it. 5 minute job.
I will check it out and bring it up to the dealer tomorrow. Thanks!
riotkayak284 ![]() Senior Member ![]() Joined: 29 Apr 2016 Location: Nashville, TN Online Status: Offline Posts: 162 |
I have had to run my propane stove for a minute or 2 to remove air from the lines.... assume you have tried that.
I did. It worked the first time I used it, then stopped.
MDPaddlersPod ![]() Senior Member ![]() Joined: 06 Jul 2016 Location: Maryland Online Status: Offline Posts: 135 |
Where is the reset button, I am having the same issue.
MDPaddlersPod
2017 RPod 179 2002 Silverado1500 |
The resets are on the left hand side of water heater, under a rubber cover. The interweb has many Suburban WH troubleshooting sites, if you don't have a warranty. Google is your friend :)
Check the simple things first. Is the gas on at the tank? You said the stove worked and then quit? Maybe you're out of propane??? TT |
FJ Cruiser |
Page 12> |
