Camile
Calendar Event: Solar panels Posted: 02 Nov 2017 at 4:15pm |
I was wondering who had experience with solar panels. What they liked, what they didn’t. And how well they provide power for just the small things. Thx!
Leo B
Posted: 03 Nov 2017 at 3:42pm |
We did some dry camping on this recent trip also and am interested in some solar panels for our pod.
Posted: 03 Nov 2017 at 4:01pm |
solar panels don't power things. they recharge your batteries.
sailor323
Posted: 07 Nov 2017 at 7:52am |
We have 2 140 watt panels on the roof.
They do a fine job of keeping the batteries charged. They do have their limitations.
Leo B
Posted: 07 Nov 2017 at 3:01pm |
Limitations such as............. How many days can you dry camp in a row with the panels recharging the batteries? Hypothetically, saying it is summer type weather and sunny
sailor323
Posted: 07 Nov 2017 at 3:32pm |
I figure we could camp indefinitely without plugging in. Limitations are that we can't use A/C or the microwave. Also, even a tiny bit of shade or cloudiness drastically affects panel output. We have a similar installation on our sailboat and have gone for weeks without plugging into shore power.
Leo B
Posted: 07 Nov 2017 at 3:57pm |
Excellent info!! Thanks!
Pod People
Posted: 07 Nov 2017 at 4:32pm |
We have a Renogy 100 watt portable solar panel. It keeps our two 6 volt batteries fully charged if we can get about 4 hours of direct sunlight. the battery usage and discharge level makes a difference in the amount of time that is needed to fully recharge the batteries. Less sun will equal less charge, as well as less discharge takes less time to recharge.
We like the portable setup because we can park the pod in a shady campsite and still have the solar panel in the sun. we have a 25' cord for the panel. We will move the panels to follow the sun in the early morning or late afternoon when we are in camp. when we leave camp. we point the panels to where we think will be maximum sun in the 11am-3pm time frame using a simple compass, knowing that the sun basically travels east to west. Not difficult to do or use.
The only drawback that we see is the necessity to carry the panel with us, take about 5 minutes to set it up and occasionally relocate it . As mentioned earlier, we cannot use the microwave or AC. this is usually not an issue with us as we prefer to boondock anyway.
If you are interested in using solar, I would suggest that you try to read and get as much info as possible before starting. it is not difficult, but there are a lot of different individual components or systems available at widely differing costs. Knowing the basics will help create a system that will do what you want and not cost a fortune. search this site for several informative articles from other owners who have installed solar panels for their pods. Vann
Vann & Laura 2015 RPod 179
Leo B
Posted: 07 Nov 2017 at 4:42pm |
Thanks Vann. What your doing sounds like what we are thinking. We can live without the A/C and the microwave. We will be using the pod lights/fan on battery, probably a 12v coffee maker and our cpap machine. We want to be able to charge the batteries each day via the solar panel(s).
Posted: 07 Nov 2017 at 4:59pm |
Unless you're only going to use your stuff between ~~ 9 AM and ~~ 3 PM (times will be dependent on latitude and season), it's best to think of solar as a daytime battery charger. The amount of power will be more than adequate for many things, but probably not the microwave or air conditioner. Each of those devices consume > 1000 watts, and would mean a drain on a 12V battery that could easily exceed 100 amps. Batteries won't last long with that kind of drain.
And just using a 100 watt solar panel (for example), you can probably get around 600 watt-hours of power for a good day (100 watts for 6 hours). Note that solar panels rarely put out what they're rated for, but are usually good for 80% of their rating, so the aforementioned 100 watt panel is going to be reliably able to produce 80 watts. This is because they won't always be aimed directly at the sun, and because there will often be clouds, and other things that reduce total output.
So if you can fit your daily power usage into 600 watt-hours, a 100 watt panel might be fine. If you need closer to 1000 watt-hours, you're going to need a 160 watt panel or so.
