  New Posts New Posts RSS Feed: Sensors
Topic ClosedSensors
mcarter View Drop Down
Direct Link To This Post Topic: Sensors
    Posted: 28 Apr 2017 at 4:22pm
They are notoriously inaccurate, but yours appears to be non functioning. Let dealer fix. You'll have enough to do without warranty.
Rodncerita View Drop Down
Direct Link To This Post Posted: 28 Apr 2017 at 4:16pm
After filling my fresh water tank my sensor still shows empty. I am positive the tank is full but it does not register on the gauge. It is a new (2017) 179 and I can take it back to dealer under warranty but was hoping it might be something simple that I could fix before driving the 60 miles to the dealer. Any thoughts or ideas would be appreciated. BTW, the gauge does light up but only shows empty.
Rodncerita
2017 R-Pod 179
2016 Ford Explorer
Direct Link To This Post Posted: 23 Apr 2017 at 8:41pm
On a side note filling your fresh water tank.  I took my white hose and hooked it up to my outside faucet then timed how long it took to fill a 5 gallon bucket - it took 40 seconds or 8 seconds/gallon.   So for the 30 gallon tank it should take (30x8) 240 seconds or 4 minutes.  I timed it as I filled the tank, at 4 minutes the water began to shoot out of the overflow hole, so now if we go for just a couple days I know if I want to take, say 10 gallons I fill the tank for 80 seconds and am good to go.
dathos View Drop Down
Direct Link To This Post Posted: 23 Apr 2017 at 4:58pm
Thanks to all. Smile
Direct Link To This Post Posted: 23 Apr 2017 at 4:51pm
The hot water tank fills when you are using city water or the holding tank, with pump on, provided you have valves in correct position.
cjscinta View Drop Down
Yes it does fill the hot water tank. Open the hot water side and draw the air out. You can go outside and pull the pressure relief valve to check it. If water comes out it is full. Don't turn the hot water switches on unless you know there is water in the tank. The inside one is propane ( quicker recovery) and the outside switch is for the electric heating element when you have ground power. Use both if you want the fastest recovery. Don't forget to turn them off when you are through camping so you don't burn the element out.
2017 R-pod 179
Direct Link To This Post Posted: 23 Apr 2017 at 4:43pm
+1, good answer.
Direct Link To This Post Posted: 23 Apr 2017 at 4:42pm
Gotcha. Thanks!  BTW, just thinking then when hooked up to city water does the hot water tank fill?  I read somewhere that it does when filling the tank.  Wish I had a manual!
Direct Link To This Post Posted: 23 Apr 2017 at 4:41pm
The gauge and sensor is for your holding tanks. It has nothing to do with the city water connection. There is no gauge for that. If there is adequate pressure the city water hookup works great. If there is not adequate pressure at the campground you must fill your fresh water holding tank up and turn the water pump on. If you are using city water leave the pump off.
2017 R-pod 179
McCall View Drop Down
Direct Link To This Post Posted: 23 Apr 2017 at 4:39pm
On my 179 it's labeled "Fresh Water Connection".  It's not really a connection, it's a fill port.
Gary E
McCall, Idaho
2017 RP179
https://www.instagram.com/erttergary/
