Page 12> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6429 |
![]() Posted: 08 Oct 2017 at 9:04pm |
Looks nice. It won't work for the 179, but I will consider doing something to avoid the crawl-over.
Datsmar ![]() Newbie ![]() Joined: 29 Jun 2017 Location: MS Online Status: Offline Posts: 5 |
Thanks John, the gotta pee thing is my big reason. I'm 74 and find it hard to climb over anything....
thanks for the video that helps.
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Datsmar,
Made you a video with answers to your questions. But the quick answers are 1x6 framing, mattress is 6" tall plus a topper, and yes the seatback fits tight and doesn't hardly move at all once set. As I mentioned in earlier posts we first made them 28" wide and that just did not work out, I always had something hanging near the edge or touching the wall and it made for restless sleep. Adding the center section alleviated this entirely even though I only use it for an arm or a leg. The biggest pluses are The added floor space during the day, More drawers for storage, I can actually use the closet to hang stuff, The whole gotta pee in the night and have to climb over the wife to do it, (sleeping bear). This mod worked out way better than I thought it would,and would not change it back for anything. Marwayne suggested flush mount drawer pulls and that is a real good Idea I just haven't done yet. rgds John
Love the twin bed mod and I am getting to change our R-180 into twin beds. Did it once on a 5th wheel and it worked out great. Couple of questions:
Did you use 1x6 or 1x8 for the framing? Is the seat back sturdy when it's used as a seat back? How thick is the mattress? Thanks LT
Changed The twin beds up a little with a lift out center section, Tried it this weekend and think i found the final solution, Still gain the added floor space during the day, and can still cuddle at night. The twin beds were just a little to skinny at 28".
Jacob Orbach ![]() Newbie ![]() Joined: 30 Apr 2017 Online Status: Offline Posts: 2 |
Thank you so much for sharing. Will seriously consider doing this.
Jason,
This one was more complicated to design than the drawers under bed mod, but the build wasn't any worse. Skill level 7, If you can build a drawer and mount it on guides (with drawer face) you could most likely do the mod. 95% of the cuts were done with a skil saw, and it's all put together with screws. I wanted full access to everything under with easy to remove access panels, Trim was all the same Home Depot shelving I used before and it was tricky only using that as trim. There is angle iron over the large drawer openings to support the plywood and face frame. What it looks like under the mattress ![]() ![]() The mattress is a 6" 3 layer memory foam queen that I Bought on amazon for $130, actually cut it with a skilsaw and a cheese knife. ![]() Rgds John |
I like the recessed handles Marwayne. The whole setup looks really sharp.
jason330i ![]() Newbie ![]() Joined: 14 Mar 2017 Online Status: Offline Posts: 3 |
This is some great work! How difficult would you say this task was? I may be interested in doing something similar. |
Marwayne, OK that looks like a better idea! I like it. You can see in the video the nightstand hit the handles.
I just had extra handles and put them on.
Page 12> |
