Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
TXpod ![]() Newbie ![]() ![]() Joined: 08 Dec 2009 Location: Tyler TX Online Status: Offline Posts: 4 |
![]() Posted: 08 Dec 2009 at 4:37pm |
For those that are really interested in Dutch Oven cooking, the www.dutchovenuniversity.com site is full of info. Here is the temp chart, with the amt of charcoal requiredon the top and the bottom.
Date Added: 2008-02-03 |
Carole & Steve
Scooter & Sophy(4legged kidos) 172 R-Pod 2008 Toyota 4Runner |
rpodcamper.com ![]() Admin Group - pHp ![]() ![]() Joined: 26 Nov 2009 Location: Reading, Pa Online Status: Offline Posts: 3990 |
Its sad to say as we emptied out the old 30' Trailer and moved items to the R-pod I had to reduce the amount of Dutch ovens. Now I only carry 1 #10 and 2 #12 Ovens. We used to have 5 with us. I make a lot as I cook as it tends to bring the other campers out looking at what we have made.
Samples anyone??? |
TerryM ![]() Admin Group - pHp ![]() ![]() Joined: 16 Nov 2009 Location: Saint Augustine Online Status: Offline Posts: 1950 |
One of these days I'll try cooking that way. I have watched it being done and tasted the results. YUMMY!
Terry |
I think
the first thing a person
should learn about Dutch oven cooking
is how to control the heat.
Most
of the cooking is done on the
top of oven. As a general rule,
you should have twice as much
heat on the top of the oven as
you do on the bottom. That is
easy if you are using charcoal.
You can simply count them. If
you are using coals from a fire,
it depends on what kind of
wood you are using and hard
woods seem to work the best. You
just have try some and see what
works the best. Any wood will
work ,but you will find that
some is surely better. I use
only Kingsford charcoal because
it is always the same.
