Page 12> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6435 |
![]() Posted: 10 Oct 2016 at 6:59pm |
Congratulations on getting it fixed. It was great that your nephew came by.
mtd66 ![]() Newbie ![]() Joined: 27 Jun 2016 Location: California Online Status: Offline Posts: 7 |
Thanks to all who replied about my low point drain repair. My nephew (who can do anything) happened to come by while I was trying to get the broken stub out of the inside of the pex line. He got a heat gun, heated the outside of the pex line and pulled the broken stub out with his fingers! I would post a picture of what the broken stub looked liked, but I never did figure out how to do pictures. The broken stub, was plastic, with several 'rings' on the outside diameter. I am guessing that when Forest River put it together, they heated the pex line just like my nephew did, and pushed the drain plug into the pex line. The 'rings' created a seal as the pex line shrunk when cooling, I guess. Their hose clamp was probably just insurance.
I will replace the broken lower point drain with a brass fitting and hose clamp from out local hardware store. Thanks again! Marty Diehl
Alaskaflyer ![]() Newbie ![]() Joined: 30 Aug 2016 Location: YNP, WY Online Status: Offline Posts: 18 |
Perhaps more than you want to deal with, but I would replace the length of hose from the t fitting just inside the floor located inside the kickplate panel under the sink. Carefully use a razor blade or exacto knife to cutout the caulking around the drain hose. While you're at it, replace the clamp t-fitting under there with a proper Pex fitting. Two compression sides to one bayonet side. If your dinette is in the slide out, have it extended for an easier reach.
If you don't want to replace the whole fitting you can simply release the clamp from the top, replace the hose with any length of hose you want from the local RV repair tool counter, clamp it again at the t-fitting, and re-caulk. Then put a better quality Pex style drain valve on the 'business' end so this won't happen again. Life is all about choices and I've found some of Forest River's choices to be peculiar. I plan on replacing these drains with a better quality fitting in the spring. |
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Online Posts: 1454 |
Threading a carriage bolt, if you can find one big enough, into the fitting is a great idea. Whatever you try, it might help to use a hair dryer, heat gun, or even a cup of the hottest water possible, to warm up and soften the hose. Or you might be able to drill it out with the right size bit. Use a bit probably 1/8th inch smaller than you need. That will leave a thin remnant of the fitting that should be easy to pull out with pliers.
TT |
FJ Cruiser |
The hose is flexible, right? Can you use a pair of pliers to squeeze the stuck part until it breaks, then remove the pieces?
OK.. can you put the hose clamp back on, locking the broken piece in place, then either thread in a bolt, or super glue in a rod of wood or something, let dry, remove clamp, pull with new "handle"?
Somebody has to lead the way!!!
Well.. in all honesty.. in 6 years, you are the first to ever report breaking a low point drain.. |
Tars
Thanks for the reply. I have tried the twist and pull method you describe, but the inner 'stuck' piece is already loose (it spins inside the blue line) but will not pull out. I havent seen anything quite like this before. Yes, I know there are two low point drains, the hot side (red) is OK. The hose clamp is off, but as stated, its spins inside the blue hose, but wont pull out. What type of plastic pipe is this? What do think about heateing with the wifes blow dryer, and then pulling? I wish Forest River could have installed something a bit more user-friendly... Marty 2016 178 Hood river edition TV 2002 4RNR V6
Try grabbing the pipe as high as you can with one vise-grip pliers and the fitting with another one. Twist and pull.
You know there are two low point drains? One for the hot and one for the cold lines. TT |
FJ Cruiser |
Page 12> |
