  New Posts New Posts RSS Feed: R dome under skirt
Topic ClosedR dome under skirt
2noose View Drop Down
Direct Link To This Post Topic: R dome under skirt
    Posted: 09 Oct 2015 at 8:40pm
I'm sure that will work just fine also.
Thanks
CAMP ON
Direct Link To This Post Posted: 09 Oct 2015 at 8:38pm
thanks a lot, worked fine
CAMP ON
Outbound View Drop Down
Direct Link To This Post Posted: 09 Oct 2015 at 6:27pm
I prefer two vertical slits at the step (cutting from the ground to about 1/2 way up, so that the middle piece can slip behind the deployed step) as opposed to a horizontal slit...
JohnBG View Drop Down
Direct Link To This Post Posted: 09 Oct 2015 at 3:03pm
I cut mine into two sections as I got tired of cutting my arms on the fender trying to slip it over the axle.  Any skeeters that come thru the wheel have worked for their meal.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
Direct Link To This Post Posted: 08 Oct 2015 at 8:31am
Thank you very much. I did not think about a horizontal cut for the step. Less cuts are better.
I appreciate your timely response.
Confused
CAMP ON
Direct Link To This Post Posted: 08 Oct 2015 at 1:27am
Pilot View Drop Down
Direct Link To This Post Posted: 07 Oct 2015 at 9:52pm
I have been starting at the back, going over the axle then running forward. With the step in I made a horizontal slit to fit over step. Then you can pull the step out. I plan on making a vertical cut over the axle. Chip clips or clips from Harbor Freight might work to seal net  to Dome.
Walt & Lynne
2015 r-pod 177
08 F150 or 2014 Explorer
Pinckney,Mi
Direct Link To This Post Posted: 07 Oct 2015 at 6:58pm
Anyone out there know how to install under skirt netting to trailer without cutting it in three sections.
CAMP ON
