  New Posts New Posts RSS Feed: Tongue mount bike rack
Topic ClosedTongue mount bike rack
CharlieM View Drop Down
Direct Link To This Post Topic: Tongue mount bike rack
    Posted: 06 Jul 2015 at 11:24am
Originally posted by JohnBG
I saw on the Forest River brochure that the offer a bike rack that takes the place of the spare tire.  Why not go with that?
Good rack, but only carries two bikes.
JohnBG View Drop Down
Direct Link To This Post Posted: 06 Jul 2015 at 9:13am
2010 R-Pod RP-171
2010 Honda Ridgeline TV
Direct Link To This Post Posted: 02 Jul 2015 at 1:43pm
One point if you are considering this approach. Assuming you are  using something similar to the E2 WDH, there may be enough room on the stock shank to accommodate the slide on bike rack. On my Pilot, using the standard E2 shank, I was only about 1/2 inch shy of the required 3" clear space. That caused me to buy the extended shank ($$$). On my present Tacoma, with the stock shank, there is zero available space. However I no longer carry my bikes there. Point is the clear space appears the be TV dependent. Check first - may save some bucks.
Direct Link To This Post Posted: 01 Jul 2015 at 3:31pm
Those are two of the reasons I liked this option. Really handy.
FamilyGuy View Drop Down
Direct Link To This Post Posted: 01 Jul 2015 at 11:42am
Thanks Charlie!  I like this solution as it allows us to carry the bikes without the trailer attached.  Thanks.  It also will allow me drop the tail gate without hitting the tongue jack (if bikes aren't loaded).
Direct Link To This Post Posted: 26 Jun 2015 at 7:54pm
Originally posted by FamilyGuy
I'm looking for a way to carry three bikes with my 182g / Silverado 1500 combo.
Family Guy,
Here's another possible solution. I carried two bikes between my Honda Pilot and RP172. The bikes were mounted on a basket/platform carrier by Swagman. Here's the general idea:
http://rpod-owners.com/forum_posts.asp?TID=3841&KW=bike&PID=36844&title=bike-carrier-with-rpods#36844
Swagman makes a line of bike carriers called towing carriers designed to slide onto the hitch shank between the TV and the TT. Although mine carried two bikes they make something similar to handle three bikes:
http://www.swagman.net/product/xp3-towing/
To provide the required ~3" space on the drawbar I needed a long shank drawbar:
http://www.amazon.com/Draw-3214-Weight-Distributing-Hitch-Shank/dp/B0016I54ME/ref=sr_1_2?ie=UTF8&qid=1376680726&sr=8-2&keywords=draw-tite+shank
This added just over 3" to the ball location, and as such, has minimal effect on the towing and tongue weight ratings. The often quoted 50% reduction of towing capacity with any extension is based on a simplification of a simplification of a simplification and edited by lawyers, there is a caution to be observed. The true answer involves mechanics and physics and depends on TV wheelbase, bare hitch rating, TV rear axle rating, TV payload rating, distance from TV rear axle to bare hitch, hitch extension length, and many individual hitch component ratings. Interestingly, the Etrailer.com site states the 50% derating, but then admits it is their own hitch extension that fails first. For some indication of the complications see:
http://www.visualsc.com/hitch_calc.htm
Note that I used an E2 WDH. Even with a full sized truck I and most other experienced owners recommend a WDH. Safety and towing comfprt are greatly improved. The WDH removes most of the hitch torque  related problems related to pure ball extension drawbars. I do not recommend any drawbar extension without WDH.
Careful measurements are required to ensure clearance between bikes and propane bottles and trailer tongue for turning. My installation worked well for me and has been copied numerous times. It has an added advantage that the bikes are on the TV so you can haul them, sans trailer, to the trail head.
Direct Link To This Post Posted: 26 Jun 2015 at 7:11pm
I use a Swagman Hitch Mounted Rack
It slips right over my Reese WDH with no modification and has worked great for us. You will see pics in my sig.
Direct Link To This Post Posted: 26 Jun 2015 at 4:12pm
Thanks Chiman,
I looked at the site and the Arvika product looks good.  Their three post design seems like it would be more stable with a high load.
I'll check out the front bumper mounts as others suggested as well.
Thanks for the input.
chiman View Drop Down
Direct Link To This Post Posted: 26 Jun 2015 at 3:31pm
Family Guy
I suggest you take a look at the front tongue bike racks made by Arvika.  They are made in Canada and are really well built and includes the mounts for the bikes so no need to buy an extra costly bike rack.  I have the two bike system but they make ones for three bikes.  Much lighter and I believe will be stronger than what you are looking at currently.  Really well made and easy to install and I have had no problems at all carrying my two mountain type bikes.  No modifications or buying other parts, bolts etc.  The rack just went on per directions.
Chiman
You can google them and get their website.
2017 180 "Frog" towed by 2017 Toyota Tacoma with co-pilot "Willow" a 80 lb Labradoodle
john in idaho View Drop Down
Direct Link To This Post Posted: 26 Jun 2015 at 3:21pm
Can you put one on the front bumper of your truck?
