Page 12> |
marwayne ![]() Senior Member ![]() ![]() Joined: 25 Oct 2011 Location: Edmonton AB Can Online Status: Offline Posts: 1003 |
![]() Posted: 31 Jul 2017 at 12:16am |
The only aluminum is on the inside of the door in all pods
spydie ![]() Senior Member ![]() ![]() Joined: 25 Jul 2017 Location: New Mexico Online Status: Offline Posts: 159 |
OK, thanks. It looks like the 2" wall thickness that others have posted is bogus. I really needed to know the thickness so I can get a window whose frame isn't too thick, thus requiring all sorts of work to cut it down. Now the search begins. We are talking about a newer model with fiberglass sides, right? I read on here that the older ones had aluminum sides, but that might not have been correct?
2018 R-pod 176
2017 RAM 1500 5.7L Hemi ![]() |
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Did the same with a drill bit, thought I was on a stud to put up a shelf and the drill bit went though the fiberglass to the outside.I had the bit set for 1 1/4" opps! Filled it with silicone. Lesson learned.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6431 |
The foam in the walls is 1" thick. The 1-5/16" is the total thickness. I accidentally punctured my outer wall using a "short" moly bolt that was a little too long thinking the walls were the same thickness as the door. Please don't make my mistake.
[QUOTE=marwayne]The walls are 1 5/16" the door is 1 1/2" thick.
/QUOTE]
I'm confused about the wall thickness. I've read the walls are 2" thick and I'm preparing to order a window for the bunk area of a 176, but I need to know if you have just measured the foam insulation or is 1 15/16" the total wall thickness?
2018 R-pod 176
I use Reflectix reflective roll insulation. It looks like foil-faced bubble wrap. I cut pieces to fit behind the shades (sleeping area and dinette) in our 179. It serves two purposes. One is to add insulation. The other is to darken the sleeping area. It seems to do a good job for both purposes.
I have not used it for the kitchen window as I want light come in there so the regular curtains are adequate. The same with the window I installed in the door. |
Ceramic heater here as well. The only window I insulated was the rear window. Cold sleeping next to. One 1500 watt heater keeps it toasty. BTW - insulating rear window also keeps it cooler in summer. The shades insulate other windows.
WillG ![]() Newbie ![]() Joined: 28 May 2016 Location: Oregon Online Status: Offline Posts: 22 |
Extra blankets work well.... we use the ceramic heater but I think the dehumidifier kills 2 birds with one stone after all this is just glorified camping. I was thinking insulating the floor or adding cork flooring would help a bit.
I'd like to get insulated windows as well. Has anyone used insulated windows as a modification? |
R-Podder by process of elimination
2014 RP179 2011 GMC CrewCab Short Bed |
samiam2 ![]() Newbie ![]() ![]() Joined: 16 Oct 2014 Location: Texas Online Status: Offline Posts: 23 |
I have 2 of the same heaters as FURPOD....Propane is to $$$ to heat a trailer.
My dog and I lived in our (The DOGS ![]() I took the trailer out to a state park in Austin, Tx in Jan for 4 days. During the days I had windows cracked/open, and at night ceramic heater on low. A fellow camper (camp ground host) couldn't believe how comfortable the heater kept the trailer. The trailer is the right size for small heaters. |
beechridge ![]() Newbie ![]() Joined: 25 Feb 2015 Location: New Hampshire Online Status: Offline Posts: 4 |
Since bringing my 171 back to New Hampshire, it's been getting down to 30 (or less) at night. I have an oil filled electric heater http://www.amazon.com/DeLonghi-TRN0812T-Portable-Oil-Filled-Programmable/dp/B000G1CXZI/ref=sr_1_4?s=home-garden&ie=UTF8&qid=1429925877&sr=1-4&keywords=delonghi+heater that I had bought to keep the water well closet heated in my home. On a low setting, it has been doing of great job of keeping the Pod comfortable while I get it ready to go. Very even heat, no fan to blow dust around, and it fits in the pass through under the bed. I've decided to bring it with me on my extended trip.
Page 12> |
