Page 12> |
Author | |||
kymooses ![]() Senior Member ![]() ![]() Joined: 01 Aug 2010 Location: Louisville, Ky Online Status: Offline Posts: 1807 |
![]() Posted: 12 Oct 2014 at 10:14am |
Will be interested to see what happens for you.
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Goal? To get FR to admit they do not use a heavy enough axle. It was not a case of "not liking" the axle- it is undersized for the application. Once the dealer contacts them about warranty replacement as I said "we'll see where that goes". If they agree to replace it I plan to ask for reimbursement instead- will cost them the same either way. If they refuse to compensate then yes, by all means they can send a new axle and pay labor to replace it. I'll then test it to see if the same problem returns. |
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
Uuuh...cost was $1200 as stated. That was for new tires/wheels/axle. Not labor as I did the labor. |
2014 179
Dexter does not sell axles by part number- you have to give them the specs to order one. IOW they require certain measurements to make one- this is all detailed on their site. If your axle currently is a Dexter you can contact them with the serial number and they can supply those specs to you. Of course you need to order the higher capacity with your old measurements. |
2014 179
Yak ![]() Senior Member ![]() Joined: 12 Jan 2013 Online Status: Offline Posts: 113 |
1000 pound tongue weight??? ![]() |
Bill-GA ![]() Senior Member ![]() ![]() Joined: 13 Jan 2012 Location: Cumming, GA Online Status: Offline Posts: 214 |
Budward, are you there?
I could really use some info on the new axle you got .... Thanks, Bill
Bill & Bev
13 yr old dachshund 'Elsa' 2010 RP-176T (tent & slide-out) 2011 Toyota Tundra 2WD TV |
I found on the Dexter.com site a section on axles called Torflex rated at 4100-6000 lbs which look like good replacement axles. Comes with hubs and brakes. I would think it costs more $$$ for the higher rated axle, so now the Q is 4100, 5200 or 6000? Since I'd be bolting up to the FR frame (assuming I don't over load my RPod) any would work. My document (sticker) says its a 4500 (?) lb trailer ... So 5200 seem's like a good choice. Old axle was rated at 3500 - how did FR get away with that?
Bill & Bev
Can you provide the details of your $1200 solution... Who from ... What ... Approx cost? Thanks, Bill
Bill & Bev
Podster ![]() Senior Member ![]() ![]() Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
I wonder what potential there is of WDH's overloading TT axles. Especially if they are not adjusted correctly.
What is your goal of putting the original axle back on? Just to get a warrantied replacement of the same axle you already have replaced because you didn't like it? Bit confused what you'd gain? Wouldn't it just be the same axle that you took off?
Page 12> |
