wingnut2312
Topic: levelers Posted: 16 Sep 2014 at 2:36pm |
Also, sandy/loose dirt sites can also cause the BAL to sink slightly. This also puts extra stress on the stabilizer jacks. Just take a look in the morning. If it looks to have sunk (this will be very, very slight) I would reccoment readjusting the stabilizers to take the added weight off of themand put in back on your leveler.
2014 rpod 182G
Ford Expedition
wingnut2312
Posted: 16 Sep 2014 at 2:33pm |
BAL. Used it on concrete, grass, and sand. Sand and grass do prove a little tricky sometimes. Sand/dirt you can just dig out the sides of the tire to fit the leveler. One thing we found, if you aren't on level ground with dirt, the leveler can shift. The weight of the pod and the shaking from movement can cause it to "slide". Only reason I mention it is because the stabilizers then have extra weight on them.
Just make sure you are as even as possible when it comes to dirt sites.
Outside of that, it works great. Never had a problem, plus its compact and fits nicely in the storage bin. You will get grease residue on your hands from the rod but that's nothing much. We also use a corded drill on the BAL, but sometimes I have to switch to hand since the drill bogs down.
2014 rpod 182G
Ford Expedition
Budward
Posted: 12 Sep 2014 at 11:38am |
Originally posted by Outbound
I must be old-school(-ish). I still prefer the combination of a Hoppy Hitch Level (which at a glance tells me 'raise the street side by 4 inches') and Lynx Levelers (with Lynx chocks). |
I'm from an even older school and just use 2x6 boards I carry in various lengths. Never failed me yet  Plus- being old if I roll off and forget them, it is just pennies for the loss
2014 179
Grayotter
Posted: 12 Sep 2014 at 10:46am |
I have a small 1 or 2" bullseye level near the front of my hitch. By looking at the level I can tell how many level pads I need under which wheel. On asphalt or concrete, if I go more than 2 pads I make a ramp with the logo pads. Gar
Love2 1der
ToolmanJohn
Posted: 06 Sep 2014 at 7:40pm |
Originally posted by furpod
I like the look and design of the Anderson, but have as of yet seen one used in person. I own and use the BAL. Like it very much. I also use legos with it if it looks to be a high lift, that way I don't have to crank as much.. lol and almost always use one lego, in case of sinking.
Exactly what I do too. Place a lego block riser in front of the lowest tire, drive up on it , then place the BAL underneath and level the pod.
The BAL will usually not fit under the tire on soft surfaces , so it's necessary to get the tire up a little so there is room to install the BAL, and also to remove it.
The BAL is great, it doesn't take very long to raise one side of the pod, and it acts like a wheel chock, I also double chock the other tire. Once level side to side, I use the stabilizer jacks to lock it in.
Outbound
Posted: 04 Sep 2014 at 8:32am |
I must be old-school(-ish). I still prefer the combination of a Hoppy Hitch Level (which at a glance tells me 'raise the street side by 4 inches') and Lynx Levelers (with Lynx chocks). Its very rare that I find myself on a level site (unless its one of those 5-star resorts  with cement pads and private hot tubs), and I usually end up having to add 3-5" to one side or the other - so a very simple, extremely stable solution appeals to me.
Hairy Podders
Posted: 04 Sep 2014 at 7:16am |
We have the BAL leveler & hauled it to Colorado with us. My buddy used it on his Scotty camper & it worked well. As for the cranking issue, I use a Bosch cordless drill set on low speed/ high torque.
Darryl, Julie & Lindsey
2014 RP178
J-Cat
Posted: 03 Sep 2014 at 12:02pm |
I have had the Anderson leveler for a couple of months and have had occasion to use it twice on uneven camp sites. My first experience was not good. It was raining and the wet surface of the two plastic pieces slipped allowing the trailer to shift which dropped the jack shaft off the wood block I had it on. Long story short, there was no damage or injury and I learned some hard lessons on better chocking the opposite wheel and using more stable cribbing for the jack but be aware the surfaces of the Anderson leveler are slick when wet. On the positive side my second use of the leveler with dry conditions worked great and you can't beat it's light weight, compact size, and quick set up. You are limited to about a 4" maximum height adjustment.
Jerry & Cathy
2015 RP-179 HRE
2013 Tacoma SR5 4x4
Posted: 03 Sep 2014 at 8:40am |
kymooses
Posted: 02 Sep 2014 at 9:44pm |
Originally posted by ron_whitt
I know Travis but like nation my post is gone right away. How can you hope to get replies if you post is gone within minutes? But thanks Travis I appreciate your input.
just so few visitors over there anymore. you have a better chance at continuous chatter here these days for sure!
