  New Posts New Posts RSS Feed: pump for water
Topic Closedpump for water
Budward View Drop Down
Direct Link To This Post Topic: pump for water
    Posted: 11 Jul 2014 at 5:54am
I noticed on mine when I drain the fresh water tank after arriving back home from a trip-   the next first use is gurgly and sometimes the pump doesn't want to shut off.  After a few minutes and opening and closing a faucet it purges the air, clears up and works fine.    Never had that in other RVs I've owned and am a little puzzled by it in the rpod.
2014 179
Old Dingo&Mrs.Dingo View Drop Down
Direct Link To This Post Posted: 10 Jul 2014 at 11:29pm
There is a plastic "filter" on the inlet side of my pump.  If the cap isn't tight enough the pump pulls air, hand tighten should be enough.
Old Dingo and/or Mrs. Dingo
181G
2013 Jeep Grand Cherokee
ron_whitt View Drop Down
Direct Link To This Post Posted: 10 Jul 2014 at 10:08pm
Also take off areoator off of tap and clean it. It only takes a very small piece of dirt to block the water coming out of the tap... Take care to remember what order you took it apart.
Ron & Shirley
2020 Tacoma
2012 177 rpod
Direct Link To This Post Posted: 10 Jul 2014 at 9:38pm
Is your winterization valve closed if not, you are sucking air.
bcmatell View Drop Down
Direct Link To This Post Posted: 10 Jul 2014 at 9:23pm
Have not checked shower but will do that and yes I have water in the tank about 2/3 full
Craneman View Drop Down
Direct Link To This Post Posted: 10 Jul 2014 at 8:14pm
Do you get water anywhere else??? Shower ??? Are you sure you have water in the tank??? Some times the gauge lies
      Moe
Jo and Gary
2010 174
2011 Ford 150
Direct Link To This Post Posted: 10 Jul 2014 at 6:45pm
Hi all, Question?? City/fresh water tank is over half full. We are dry camping, when I turn the water pump on and turn the sink tap on the water barely comes out,gurgles and sputters . I hope I spelled that right,LOL.
Whats wrong?? Need help
